Danny's And Jeff's 6A13 turbo Conversions
- dannyboyau
- RichardB
Bored of the twin now, time to joing the single turbo club
http://www.mitsubishi-fto.net/cgi-bin/a ... height=500
- dannyboyau
- RichardB
The aircon went a long time ago, howeve I have just removed the pump so I can get the pipework in. The driveshafts, one was found to have a default which caused it to break which resulted in the other letting go so Im still on standard ones at the moment, and carrying a spare set in the boot!dannyboyau wrote:looking good mate
what size is your intercooler core ?
and have you lost the aircon ?
what have you done about the driveshafts ?
Intercooler.... massive... not sure to be honest I will measure it when I get chance.
- dannyboyau
Link to a video of my FTO in september/october 2005 http://videos.streetfire.net/video/B7CF ... 0B4004.htm
- RichardB
sounds like your getting bad traction problems.... but looks good. I posted a new PB the other day of 12.41 so youve got some catching up to do
- dannyboyau
- dannyboyau
- Nacho
Hey Danny is there anyway to retain the sequential twin turbo setup of the 6A13TT in the FTO?
Is there any other way to run the intake pipe (closest to the firewall) below the other turbo so it doesn't hit the suspension mount?
Did you have any ideas or did you always want the single turbo setup?
- Liquidity
I dont know about the 6a13tt specifically, but i'm under the impression most "factory" TT setups, can nowadays be outperformed by newer technology.
Ie, a single variable vane, ball bearing turbo, will spool earlier, hit boost more progressively, and if needed, harder, with less plumbing etc headaches.
I've also read (here no less) that you need either a new exhaust manifold, or a firewall mod, to fit the 6a13tt in its "bone stock" form...?
- FTO338
- Nacho
So you change the turbos if there's extra room and retain the sequential turbo setup so you get power on the low end and high end of the scale.Liquidity wrote:I dont know about the 6a13tt specifically, but i'm under the impression most "factory" TT setups, can nowadays be outperformed by newer technology.
- Liquidity
if you want low end power, supercharge it. Actually, come to think of it, a supercharger/turbo twin setup would probably be easier than a custom made twin-turbo setup (assuming you have to remake the manifolds to fit it in the engine bay).
But as i said, some "new tech" turbos will spool earlier, and harder, than factory twin sequential setups.
- FTO338
I've got a supercharge RWD, but the power are mid to high (factory tune). So supercharge doesn't always mean good low end.
If you talking about titanium blade, twin scroll or the new 997 with variable turbine geometry, they cost an arms and legs and that if you can get your hands on one.
But i would have say Joel, you better off with single turbo then a twin, it take up less space and you can also mix and match the turbo to suit your need. With a smaller inlet housing and a larger exhaust housing (T28/40), it will give you a quick spoon up for low end and good mid to high end. Well provided all the other parts are matched.
Ohh and here's a link we did eariler that have supercharge with twin turbo setup, its not a FTO, but you can tell it aren't easy to do a setup like that.
http://www.ftoaustralia.com/modules.php ... 24&start=0
- Nacho
- dannyboyau
The 6A13 TT is a Parallel Twin-TurboNacho wrote:Hey Danny is there anyway to retain the sequential twin turbo setup of the 6A13TT in the FTO?
get custom made intake pipingNacho wrote:Is there any other way to run the intake pipe (closest to the firewall) below the other turbo so it doesn't hit the suspension mount?
big single turbo is less custom made piping then a twin turbo system so saves money and timeNacho wrote:Did you have any ideas or did you always want the single turbo setup?
- dannyboyau
Do you know how sequential turbos work ?
with out getting into a complicated explanation a parallel twin turbo is basicly two turbos working together each one is running off one cylinder bank then combiming the air after the turbos.
- Liquidity
Yes, you can run different sized turbos, one per bank. Basically, on the small turbo, it will spool earlier...then as it reaches its limit, hopefully you've chosen a larger turbo that starts spooling at that point, and the smaller one will open its wastegate so it doesnt get "overloaded".
another way is to run exhaust through the larger turbine first, and then through a smaller one.
Exhaust at low rpm doesnt spool the large turbine, but does spool the small one.
Once exhaust hits a certain flow (rpm) the big turbo will start spooling. At this point a wastegate in the small turbo usually opens, either to 'cut it out' or to maintain it at low psi.
Theres other more complicated systems, where you divert exhaust gases according to which turbine you want.
- dannyboyau
where did you get your information on how a sequential turbo system works ?Liquidity wrote:Yes, you can run different sized turbos, one per bank. Basically, on the small turbo, it will spool earlier...then as it reaches its limit, hopefully you've chosen a larger turbo that starts spooling at that point, and the smaller one will open its wastegate so it doesnt get "overloaded".
