Or part it out
get a screwdriver and put it in the slot you made a d try and bash it in the undo direction with a hammerdestinationtoby wrote:I've tried it all man lol circle inside and out now. Nothing fits close enough to bash in. Even if I could there's not enough room because of the stud (reason for stripping it in the first place) nothing will go on the outside because there's 1mm clearance between the nut and the wheel. Can't grind slots any deeper without damaging the wheel.
Might just throw a Granada at it
If you keep bashing it you might break off any bit left to use.
Take it to a workshop and get them to weld a nut onto it, then undo it with the welded on nut.
Just make sure they put a protective barrier around your rim to protect it.
Rip out your whole suspension and hub setup in one go?
Bash the crap out of the rim until it falls apart and then you should be able to save the stud
- Shhtuart
Degreased the underside of the engine. Left an oil slick in the driveway
Next job is the tie rods.
I have begun doing thisDaniel2019 wrote:Rip out your whole suspension and hub setup in one go?
Reciprocating saw went straight through the toe and camber arms and the hub bit lol
Not sure if serious..
Bennoz where's that new diddly meme?
I did lol I've got all the parts to replace whatever I have to break.
I'm kinda facepalming but at the same time it doesnt surprise me
Began stripping down the gearbox side of the engine bay.
Why does the gearbox in the car have an LSD stamped number on it....
Fair bit more work to tackle as the battery has been leaking acid. Nice paint stripper that stuff is.
except not.Vectose wrote:Had an LSD all along.......
No 11s, just a 1.
lol
And no, not LSD #1.
LSD?
Bennoz hasn't been working on it has he?
Broken diff? Would explain your noise.
Actually you could be onto something thereVectose wrote:Broken diff? Would explain your noise.
Wrong oil because he thought it was non lsd
There's a Dexron III LSD oil?Sahin wrote:Wrong oil because he thought it was non lsd
And I thought we already discussed this in another thread. Our LSD's don't require a special oil.
