- mezje
Installed the head unit, amp and sub I had lying around, fixed the rear speaker wiring too as it was disgusting. Came up a treat despite haveing a 2-part 'bit' now.
- Scorpionwally8
No reason really just having a play arounddestinationtoby wrote:How come? Stock one looks a lot neaterScorpionwally8 wrote:Got rid of the stock air hose and replaced it with a multiflex hose 76mm
Umm, yeah, I wouldn't be using a flexi pipe there.Scorpionwally8 wrote:No reason really just having a play arounddestinationtoby wrote:How come? Stock one looks a lot neaterScorpionwally8 wrote:Got rid of the stock air hose and replaced it with a multiflex hose 76mm
They have the tendency to split in the corrugations and you don't want air going in that isn't being filtered.
They're more suited for running air from the front bar to the air box.
- Scorpionwally8
Yea good idea I might have a play around and with thatVectose wrote:Umm, yeah, I wouldn't be using a flexi pipe there.Scorpionwally8 wrote:No reason really just having a play arounddestinationtoby wrote:How come? Stock one looks a lot neaterScorpionwally8 wrote:Got rid of the stock air hose and replaced it with a multiflex hose 76mm
Fixed my problem with the White version R Gearbox
dstocks wrote:Fixed my problem with the White version R Gearbox
Front windscreen out again. Didnt glue it in well enough last time
- mezje
Replaced the stepper/idle control valve, holy sh*t what a world of difference! The car used to idle at about 400rpm, often dipping to 100-0 and cutting out. Now it idles at about 1000rpm smoothly.
Rubber gasket was a bit stretched and took a lot of gentle pushing to fit, longest part of the whole thing
- BorepYano
found my old car, got nostalgic, felt sad.
the end
the end
I went and checked it out yang tried swapping ifs out no go
- Scorpionwally8
Ripped out the stock feeder tube and replaced it with flexihose running from the airbox to the front grill
Sorted all my spare parts. :lol:
Well most of them, got a lot more on another shelf....
Took it (the starlet) on a gravel hill climb.
Video, skip to 40 odd seconds.
Got 1st in my class!
I was the only person in my class...
But, because I was first in my class, I got the full 25 points in the championship, so I have the same number of points as the person who got the best time of the day!
Looks much like my Bunnings rackingVectose wrote:Sorted all my spare parts.
- bjk
- Totes
Acquired more parts!
New Wavetrac?
That was quick!
That was quick!
- bjk
- Totes
Sorta quick I spose. Arrived on Thurs but I wasn't home.Technikhaus wrote:New Wavetrac?
That was quick!
Wavetrac it is.
I need one of these, haha.
- bjk
- Totes
How's the exchange rate for you? :pTechnikhaus wrote:I need one of these, haha.
Quaife might even be cheaper soon enough.
