Ok guys, does anyone want high beams? I'll need to know so I can add them to this order.
Cheers,
L.
*** CHEEEEAP HID Kits! ***
- gotboost?
- ZFL45H1
CHEEEEAP 9006 (HB4) HID Kits!
Yes please 6000k high beam will pay on Wednesday cheers
- gotboost?
Re: CHEEEEAP 9006 (HB4) HID Kits!
Thanks ZFL45H1 !
Just an update, all - You may find that you need to reverse the wires just before the ballast, as I found from the Irish FTO forum.
Despite the kits being suited to Japanese cars, apparently the FTOs do something funky in the headlight department...
So, if you receive a set and believe that they don't work, just test them out direct to the battery first. In nearly every case, it's just the reverse wires. I'm testing each kit before sending it out anyway.
