Cheap Quality Tires Hookups
Valandis91
Re: Cheap Quality Tires Hookups
Post by Valandis91 »
bass_twitch wrote:Oh well, too late.
I'm getting the falkens on Saturday,
I'll let you know how they go :D
Thanks for all your help and input :D
you wont regret your choice! :D
595's are sh*t, had them for like 4 months and all 4 are getting low on tread. Shithouse in the wet.
silverGPX wrote:595's are sh*t, had them for like 4 months and all 4 are getting low on tread. Shithouse in the wet.
595SS*
Gholdwayne
Post by Gholdwayne »
I'm sorry but I'll have to agree... But on the dry, it's good until the tread is low...
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
Gholdwayne
They grip pretty decently in the wet! I have Falken ZE-502's on the rear, and I pushed in a big roundabout in the rain, and the fronts gripped well that the back slid out and it did a 90deg, ended up facing the roundabout 8O
But im pretty sure it also has to do with my rear toe outs ranging from 1 to 3.8 which apparently cant be fixed to toe in as the bolts were maxxed out, so i was told.
97 GPX Icelle Blue
FTO[For The Orgasm]
Holy sh*t, why are they out so far, they should be at 0 standard. Sounds like something is bent? What camber are they at as that affects toe as well. Who aligned it?
Gholdwayne
I told them to do the camber to be around -1.2 to -1.4 which it is now.
Something is definitely bent 8O
The fronts were done right... Just something with my control arms i think. It was done by jaxquickfit, altho they did a good service, its a fault in my car sadly.
97 GPX Icelle Blue
FTO[For The Orgasm]
evoman
Post by evoman »
I don't have any problems with wear. 30k and still about 60-70%, and dry performance is pretty good, but I agree these are THE MOST useless tyres in the wet. I am endlessly amazed at how crap they are.
Gholdwayne
The wear on my last 595ss's were mostly from camber wear and the outside tread... The middle was still pretty decent. Just annoying, when 1st gear mivec is useless in the wet, and sometimes even 2nd :lol: even in a straight line...
97 GPX Icelle Blue
FTO[For The Orgasm]
I have eagle f1 kills it in the wet. 255's fit on the rears as I use to have them.
wcefan
Post by wcefan »
I'll post my question here instead of opening a new thread.
Is anyone running with kumho ku31's? If so, how do you find them?
Also is anyone running 225 45 17's on 7" wide wheels? How are they and is there rubbing at all?
Cheers guys.
wcefan wrote:I'll post my question here instead of opening a new thread.
Cheers guys.
I'm running 225 45 17, not sure on the width of my wheel though, but no rubbing at all which is good :)
Cheers guys.
I have 225's on the front as well ... No issue what so ever.
Option one garage sells ku31 but they are located in brisbane.
wcefan
Post by wcefan »
rock_it wrote: I have 225's on the front as well ... No issue what so ever.
Those on 7" wide wheels?
Pretty sure they are .. Don't think they are 7.5" ...
Although I have been wrong before... Well only once... :lol:
Have eagle f1 gds3. Motor mag did a test on them and they stopped a car better in the wet than dry! Storage!
Same happened in the Goodyear assymetrics.
The GDS3's used to be good when they were made in Europe, now they made in Asia... still good, but not what they used to be.
