Re: dstocks
That looks amazing, how come only sprayed the front wheel? How much did the respray cost or is it a wrap?
- bjk
- Totes
Re: dstocks
It's wrapped like the rest of the car. Hence why there is currently only one done.
wheels are triccky apparently.
Re: dstocks
Actually, have purchased some anthracite spray wrap. Going to try that instead as the vinyl wrap on the wheels just isnt going to work (too many curves and the vinyl is starting to lift). Failing that, will by some similar gun-metal rims a bit further down the track.
- bjk
- Totes
Re: dstocks
How many colour varieties does it come in? Let us know how easy it is to remove.dstocks wrote:Actually, have purchased some anthracite spray wrap. Going to try that instead as the vinyl wrap on the wheels just isnt going to work (too many curves and the vinyl is starting to lift). Failing that, will by some similar gun-metal rims a bit further down the track.
Re: dstocks
A few different colours.
http://www.foliatec.com
http://www.youtube.com/watch?v=A6aouI83Kgw
I wont be trying to remove it. Just put it on. But if you watch the video, you can see for yourself.Let us know how easy it is to remove.
- bjk
- Totes
Re: dstocks
Hmm. I may consider this. Was keen on gold rims while I was looking for them.
Re: dstocks
Good job on the Vinyl, looks awesome.
I don't think i would have the patience to do something like that.
Re: dstocks
You could powdercoat them
Re: dstocks
Yeah, could have. Got told id be defacing the SSR rims if I did that. This way, its reversible. Have replacement SSR stickers to put on as well.
Re: dstocks
I don't think anyone would notice
Re: dstocks
Maybe, but had the guilts about it, so decided to go this path.
- rock_it
Re: dstocks
Sorry ...dstocks wrote:Maybe, but had the guilts about it, so decided to go this path.
- bjk
- Totes
Re: dstocks
It's all your fault.rock_it wrote:Sorry ...dstocks wrote:Maybe, but had the guilts about it, so decided to go this path.
Re: dstocks
It bloody well is too
Re: dstocks
Plus you can't powder coat rims, or the world will end.. Ask Vectose
Re: dstocks
These arent steelies, they are one of the good light weight ones ex Japan , so not sure what that means re powder coating. I know the powder coasting process requires things to be heated up a lot and not sure what it would do to rims like this. May make them brittle. Dont know.
Re: dstocks
Never said it's the end of the world.destinationtoby wrote:Plus you can't powder coat rims, or the world will end.. Ask Vectose
Just said it isn't a good idea to powder coat alloy wheels as they've already been heat treated/powder coated from the factory. And putting them through another heat cycle can weaken them.
Re: dstocks
Vectose wrote:Never said it's the end of the world.destinationtoby wrote:Plus you can't powder coat rims, or the world will end.. Ask Vectose
You can definitely powdercoat wheels without weakening them, they can lessen the heat produced to ensure they dont weaken them. People powdercoat them all the time! I even powdercoated my motorbike frame and it was fine.
Option one garage even offers powdercoating of rims to your specs.
Powdercoating is going to be the strongest and best looking paint.
Re: dstocks
nah mayte ya carnt du eitsilverGPX wrote:Vectose wrote:Never said it's the end of the world.destinationtoby wrote:Plus you can't powder coat rims, or the world will end.. Ask Vectose
