Installing clutch pedal
Re: Installing clutch pedal
Holy f**k lol
I lost my nail from the gear box the other day
- vanadinite
Re: Stupid Injury Thread
![Image](https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-ash3/133800_10150104570241151_4216562_o.jpg)
Is that a k-wire sticking out the top??
- Shane001
Does the clutch have to be bleed to work?
Could some one get a photo of the attachments on the Line from the cylinder to the reservoir please?
And the engine is sounding a lot noisyer then what it was before.
https://www.youtube.com/watch?v=r7MjPEIPWdU
Does that ^^ sound like tappets or something else aswell. The last bit, noise is coming for the pulley & belts area??..
- vipfto
Yeah bleed it. Line goes from master across firewall back over top gearbox then into slave. With various spots being clamped on box and firewall. Sorry I had to do braided line that runs round front for mine so cant use mine as reference
Mine is clashing with the engine . The selector arm has fuckall movement. As though its jammed or somethingvipfto wrote:Yeah bleed it. Line goes from master across firewall back over top gearbox then into slave. With various spots being clamped on box and firewall. Sorry I had to do braided line that runs round front for mine so cant use mine as reference
![Shocked 8O](./images/smilies/icon_eek.gif)
What's do u guys think about my idea of making up a bracket plate with the holes cut for the pedal then bolting to the fire wall? Will it work?
Did you change the bearing on the clutch fork?
YepsilverGPX wrote:Did you change the bearing on the clutch fork?
- vipfto
destinationtoby wrote:Mine is clashing with the engine . The selector arm has fuckall movement. As though its jammed or somethingvipfto wrote:Yeah bleed it. Line goes from master across firewall back over top gearbox then into slave. Witpots being clamped on box and firewall. Sorry I had to do braided line that runs round front for mine so cant use mine as reference![]()
Ok can you take a pic of what damage is already? Your idea may work but remember the rod still has too reach pedal and have movement And pedal bracket is what holds master in place. Will need proper bleed to make fork work same principle as brakes hydraulics
Cool then.. Well ill have to rip it all back out to make up the plate and bolt it in.. Then bleed it and hope everything work fine.vipfto wrote:destinationtoby wrote:Mine is clashing with the engine . The selector arm has fuckall movement. As though its jammed or somethingvipfto wrote:Yeah bleed it. Line goes from master across firewall back over top gearbox then into slave. Witpots being clamped on box and firewall. Sorry I had to do braided line that runs round front for mine so cant use mine as reference![]()
Wil get a pic when I can.. Back to work tomoz
Hooray!!!!
Got oil in the gearbox?
- Shane001
Bennoz wrote:Got oil in the gearbox?
Auto one recommended this one . Figured it will do for now? Is suitable? http://www.penriteoil.com.au/products.p ... oducts=375
It's cheap as f**k, so but weary of it ![Confused :?](./images/smilies/icon_confused.gif)
And dot 4 clutch fluid? Yes or no?
same as brake fluiddestinationtoby wrote:And dot 4 clutch fluid? Yes or no?
Sahin wrote:same as brake fluiddestinationtoby wrote:And dot 4 clutch fluid? Yes or no?
Which is?
