Jono's TURBO Research, Questions and possible Application!
khunjeng
Post by khunjeng »
also cbf reading again
the turbos u are talking about are internally gated anyway...for such small rating they must be...
no need for external at all..
FNTSY
Post by FNTSY »
just did some reaserch and the gt17 at 4 psi will have a choke line at around 150 fly wheel hp, i wouldnt even recomend this turbo for a 1 litre 3 cyl charad,
just trying to help you out as u may get through this and make less power then when u started if u put a turbo like this on. and it costs a bit to change turbos down the track
FNTSY MOTORSPORTS NEWCASTLE
###for all your boosting needs###
RedlineGX
Post by RedlineGX »
To be honest if you cant afford to t/charge your car properly then dont start because you'll probably find yourself trying to cut a lot of corners along the way and end up damaging something. Save a bit then do it.
Everything FNTSY said is true...just because you might be able to get away with something for a time...ie. running no intercooler doesnt mean its a good thing. You would have to retard timing so much that you would lose power and even so it will have a much shorter life span.
My car only sees stoich at idle after that its in 13z till boost then 11s on boost. Timing retards to -5 at some points but advanced a couple degrees pre-boost. Thats at 5psi.
FNTSY
Post by FNTSY »
redline GX
yeah thats what i was saying about the air fuel gauge it will sit on rich for most of the time.
RedlineGX
Post by RedlineGX »
Yeah i forgot how crappy the standard air/fuel gauges are. I have in an AEM UEGO gauge and it works great.
jonowong
Post by jonowong »
im going to be back soon, im going to relocate that f**king battery only cost $200 anyway...
now i need your opinions, should i get a T25H or a T28 or a TD04L?
what are your opinions on these turbos and why?
thanks a lot lads, happy new year
khunjeng
Post by khunjeng »
jonowong wrote:im going to be back soon, im going to relocate that f**king battery only cost $200 anyway...
TD04L is a small turbo off the rex...from memory.
personally would'nt have the T25h as you can get a T28 cheaper and holds boost better and can take more boost generally from what I have been told.
the t25 will spool faster and is probbaly just fine for your applciation as low boost...
AJCFTO06
Post by AJCFTO06 »
jono you got a GR or gpx?
jonowong
Post by jonowong »
gpx
FtoSam
Post by FtoSam »
theres just something about a turbo mivec... :twisted:
jonowong
Post by jonowong »
wakekeke
fto617
Post by fto617 »
are you realli turboing yo your fto?
thought u have a s13 adn also got an 180sx?
past ride : FTO gpx with lots of bling bling
Current ride: EVO 8 with the MOST CARBON IN AUSTRALIA....206KW AT ALL WHEELS
jonowong
Post by jonowong »
i have s13 :p but not a 180sx
sublime19
Sooty!
Post by sublime19 »
ok fukn hell.. just a quick question.
how much would EVERYTHING cost all together including a turbo?
i know u'd have to get a new clutch, and no doubt a new gearbox(please confirm)
would have to upgrade to 4pot calipers, new ecu, so including all that, wats the price you'd be lookin at, just curious.
EURO
Post by EURO »
sublime19 wrote:ok fukn hell.. just a quick question.
hasn't this been discussed a million times? I think the general consensus is anywhere between 8-20 grand depending on who does the work, new and second hand parts, how much power you want to generate etc.
You do not need a new gearbox - brakes I imagine only need upgrading if you are running it off high boost - but would probably be advisable either way.
jonowong
Post by jonowong »
well heres my estimate with 2nd hand and new parts..
1. downpipe = $500
2. turbo manifold = $1300
3. T25H or T28 or TD04L TURBO = $200
4. Silicone hoses = $80
5. intercooler = $100
6. universal intercooler pipes = $200
7. oil feed line & return line & vacumm lines = $150
8. blow off valve $100
9. fuel management unit $150
10. Gauages + Pillar Mount $200
11. Battery Relocation Kit $100
$3100 in parts
labour will be done by myself
sublime19
Sooty!
Post by sublime19 »
alrite, was just wondering.
btw yea the brakes would definately need to be upgraded, considering GRs have 1 pot.. :?
jonowong
Post by jonowong »
got my turbo now need to source some other parts
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... &rd=1&rd=1
jonowong
Post by jonowong »
do you guys think i should use 2" or 2.5" piping for the intercooler piping
keep in mind that i have a tiptronic... it limits space quite abit...
is 2" laggier than 2.5" piping?
FtoSam
Post by FtoSam »
The bigger the better my man.
