Moderators: IMC , Club Staff
Posts: 3955 jedwabna poszewka promocja
Post
by Vectose » Sat Jul 23, 2016 8:58 pm
Swapped out the Kaze fenders for the stock ones. Was getting over the top vents and poor alignment.
Had to drill a extra bolt hole in each fender to pull the bar up tight.
Before extra bolt
After extra bolt
Installed the dual pump washer bottle I had lying in the garage for over 2 years.
Also raised the front 1cm so should now sit at 11cm.
Bennoz wrote: Technikhaus wrote: What is in said Bens big penis by the way?
A whoooole lot 'o jism
Posts: 2915 Joined: Wed Mar 03, 2004 6:00 pm
Post
by spetz » Sat Jul 23, 2016 11:47 pm
What's the purpose of the dual pump?
More water pressure, or for a rear washer?
Posts: 6793 Joined: Tue Oct 13, 2009 5:00 pm
Post
by silverGPX » Sun Jul 24, 2016 12:13 am
Should hook up an inter cooler spray EVO style
Posts: 3955 Joined: Sun Nov 28, 2010 8:45 pm
Post
by Vectose » Sun Jul 24, 2016 7:03 am
silverGPX wrote: Should hook up an inter cooler spray EVO style
Yup, that was the plan from 2 years ago. Have had all the bits just never got around to it.
Posts: 23687 Joined: Fri Jan 21, 2005 6:00 pm
Post
by Bennoz » Mon Jul 25, 2016 10:49 am
Vectose wrote: silverGPX wrote: Should hook up an inter cooler spray EVO style
Exactly the same plan. One of these days I'll install mine.
Posts: 6144 Joined: Sun Oct 04, 2009 5:00 pm
Post
by Kustom » Wed Aug 03, 2016 6:18 pm
Watch them slip on spacers mate, geez.
I've got that but for my rad
Taz wrote: When funds allow
Post
by Vectose » Wed Aug 03, 2016 6:20 pm
Watch them slip on spacers mate, geez. [emoji14] :lol:
:lol: And I've still only got 2mm clearance with my brakes.
Posts: 3670 Joined: Sat Sep 06, 2003 5:00 pm
Post
by payaya » Sat Sep 03, 2016 12:04 am
Gearbox went for the third time left me again with no drive at a set of lights. Stuff paying 3k again rebuild it myself, $700 all up and running sweet. Splines in torque converter gone, opened up gearbox, clutches worn down to the steel so got a re-seal kit, steels clutches and rebuilt uprated torque converter!
Posts: 7957 Joined: Thu Jan 12, 2012 12:25 pm
Post
by Daniel2019 » Sat Sep 03, 2016 8:29 pm
payaya wrote: Stuff paying 3k again rebuild it myself, $700 all up and running sweet. Splines in torque converter gone, opened up gearbox, clutches worn down to the steel so got a re-seal kit, steels clutches and rebuilt uprated torque converter!
You are a patient man.
Bennoz wrote: I got Bali beli & sharted on my phone. But it was fun
bjk wrote: you old people are no help at all.
Post
by payaya » Fri Sep 23, 2016 5:33 am
for from it! Hardest part is putting the box back with just a jack.
Sorted the 2-3 flare as well. Its either the accumulator piston behind the valve body or the rear cover seals that sorted my flare!
Lawso
Penis Fingers
Posts: 2458 Joined: Sat Apr 05, 2008 5:00 pm
Post
by Lawso » Wed Nov 17, 2021 3:27 pm
Looked at them both
Shrugged
Walked away
Posts: 5762 Joined: Tue Oct 04, 2011 1:34 pm
Post
by bjk » Wed Nov 17, 2021 6:05 pm
Lawso wrote: ↑ Wed Nov 17, 2021 3:27 pm
Looked at them both
Shrugged
Walked away
Didn't even look at mine
getonit
Posts: 274 Joined: Fri Sep 11, 2015 1:26 pm
Post
by getonit » Thu Nov 18, 2021 5:57 pm
Hosed the bird sh*t off the windscreen. Called it a c**t and went inside and drank beer.
Post
by Bennoz » Mon Nov 22, 2021 11:01 am
Yeah, looked at mine, procrastinated about fixing the fuel blockage, then had a Viagra & got tin the hot tub with the missus.
I've had 6 wanks this morning btw.
getonit
Post
by getonit » Tue Nov 23, 2021 4:59 pm
Bennoz wrote: ↑ Mon Nov 22, 2021 11:01 am
If one wank was in the car, that counts as work.
Post
by Bennoz » Sun Dec 11, 2022 7:57 am
New stepper & TPS in snoor3!
getonit
Post
by getonit » Sun Jun 25, 2023 6:21 pm
I put seats in the c**t, and that is more than it deserves.
cupidsetaceous
Posts: 1 Joined: Thu Jan 04, 2024 8:36 pm
Post
by cupidsetaceous » Thu Jan 04, 2024 8:38 pm
In the quest for a more balanced audio experience, I'm now considering alternatives. The Pioneer Slimlines have caught my attention for their low-profile design, and I'm intrigued by their potential to deliver that extra punch without sacrificing too much space. Additionally, I'm contemplating the idea of going for a conventional 10" Kicker sub, which might offer the right balance of size and performance.
The goal is to find something compact enough to snugly fit between my back seats and the rear strut bar while still enhancing the bass beyond what my current 6x9s deliver. If anyone has experiences or recommendations in this realm, I'd love to hear them. The quest for the perfect blend of sound and space efficiency continues!
