Gholdwayne
Post by Gholdwayne »
Val, that kaze lip is really enticing me, nice pic there! and sig...
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
Valandis91
Post by Valandis91 »
Gholdwayne wrote:Val, that kaze lip is really enticing me, nice pic there! and sig...
cheers! except the sig needs updating!
bduffman
Post by bduffman »
pulled every thing out and replaced heater core pipes was a massive job
tomorrow prob attach pipes in engine bay and put more radiator fluid in
then get aircon tested and gassed
renzkuken1
Post by renzkuken1 »
PAYED MECHANIC 12 hours service 76 bucks an hour
900 dollars for labour and 2300 total for oil repair and defects clearing + new bigger battery.
Pick up car from sydney tomorrow.
zuihoujueding
Post by zuihoujueding »
thats pretty cheap labour.....
it its the quality of work that counts after all. hope this process mends everything
bduffman
Post by bduffman »
dosent sound cheap to me , thats a f**k load of cash i had timing belt tappets seals gaskets oil water pump ect ect fitted for 900 or so
mr-charisma
Post by mr-charisma »
gave it a much needed clean out :P
zuihoujueding
just looking at what u stated $76 per hour. thats cheap.
oh i did not look at the amount of work involved thou.
renzkuken1
ill write what he did..
JOb:
Rectify oil leaks at cam carriers and camshaft seals
supply and fit new battery - upgrade to larger battery and fit hold clamp down
supply and fit new CV drive shaft boot
tighten passenger ball joint and suspension
supply and fit new timing belt kit
inspect timing gears and tensioner
fit new belt and adjust to correct tension
Battery hold down : $18.09
2 x position battery terminal : 6 + 6 = $12
boot kit cv : $117
Heavy duty battery : $136
carbon clean : $12
Timing belt kit FTO mivec : $359
2 x seal cyl head genuine : 33 +33 = $66
sealant blue : $15
engine bay degrease/wash : $18
workshop consumables : $7
labour (12 hours at$76 an hour) : 12 x 76 = $916
GST $200 bucks
So that's a total of $2231 with a quote i asked before to be overquoted as he wasnt quite finished when i need to pay.
What does everyone think???
mr-charisma
well, you've paid him already, so I guess it doesn't matter, but I'd have been expecting more for that kind've money
the only real work he's done is the oil seals & timing belt?
AFAIC, you seem to be overcharged for a few things;
CV Boots should be at most $60 for both i reckon
Timing belt no more than $130-150
workshop consumables? geez..
And you could have saved yourself some money doing the simple stuff;
Battery replacement
Cleaning, engine bay clean
CV Boots.. maybe
A few things he should've done at the same time;
Water pump
Spark plugs
renzkuken1
hmm k thanks for the info
mr-charisma
what you've put up there should only total $1876.09 ??
Also, 12 x $76 is $912 .. maybe he's calculated it wrong on the bill?
dr390
Post by dr390 »
renzkuken1 wrote:ill write what he did..
JOb:
boot kit cv : $117
carbon clean : $12
sealant blue : $15
GST $200 bucks
shiiiet man where did you get your money tree, i wanna grow one :lol: at least man all defect free man ;)
Tell me when i stop
Uploaded with ImageShack.us
bduffman
Post by bduffman »
yes but depends where you get the parts i bought most of my parts from camskill
but didnt buy water pump so he got it from the dealer and it was like $200 plus
you could have saved a lot if you sourced the parts your self but being away im sure you didnt have time and just wanted it done
i also saved by getting my mobile mechanic and paying him cash so no gst was pretty happy he came picked it up and droped it off late that night
renzkuken1
yeah it was needed pretty quick, and i wasnt in the state to have it seen to getting done properly.
And he charged me 343 for supplying and fitting the timing belt kit lol
ALso i rounded off that's why it didnt add perfect lol
Hopefully i have no more troubles under there for a few years haa
WTF is 12 hours labour then?
renzkuken1
ok guys need help asap
he didn't replace rear engine mount which is f**king noticeably broken!!!
so i need to find someone in sydney that has one i can drive over to and buy!
it's urgent or if you know somewhere i can get one for monday so i can get it fitted monday as i need to drive to melbourne from sydney tuesday to start work wednesday >.<
Can anyone help me!?>!
bduffman
Post by bduffman »
did a bit of work on the car today
changed oil and oil filter
flushed and changed radiator fluid and connected the heater pipes back up
rewired my prefacelift parkers ( fog lights didnt work ever so did the cheat way and wired them to parkers and replaced parker with blue led )
pretty happy with the days work
Gholdwayne
Did some interior cleaning and did a little bit of headlight sanding for today. Awwrsomez.
renzkuken1 wrote:ok guys need help asap
PM my mate Ollie, he bought his engine mounts here in Sydney. As for the engine mount being broken, do you notice any noises/clanks from the engine bay while driving? If you are desperate, I have my old engine mounts which are not in great condition, though they look like they can still be used for a few thousand KM's more.
97 GPX Icelle Blue
FTO[For The Orgasm]
bduffman
Post by bduffman »
same with shane on his half cut depending if his are alright and hes not keeping them as spares
