Is this c**t still hereShane001 wrote:Toby, always good for a laughshadowarrior wrote:Sigh...of course you have..no one is doubting you..but you seem to have lesser IQ/research skill about the topic in hand. Have been friendly and answered what you needed to do...but since you skipped that entire part...go ahead and re-read my last post.
The Suspension Thread
Re: The Suspension Thread
- Shane001
Yes, forever haunting youdestinationtoby wrote:Is this c**t still hereShane001 wrote:Toby, always good for a laughshadowarrior wrote:Sigh...of course you have..no one is doubting you..but you seem to have lesser IQ/research skill about the topic in hand. Have been friendly and answered what you needed to do...but since you skipped that entire part...go ahead and re-read my last post.
- shadowarrior
- Tightarse
Fuckin camber and toe arms!!!
I done both sides in 25 minutes which included taking the wheel off and jacking it up
But I had no bolts that got stuck in the bush so I'm lucky I guess
- shadowarrior
- Tightarse
Sorted out the stuck bolt...that took some bloody time... now got to adjust them..it has too much camber and toe... :\
Getting around to modding at 250,000kmsSahin wrote:I done both sides in 25 minutes which included taking the wheel off and jacking it up
Gotta run the engine in mate.silverGPX wrote:Getting around to modding at 250,000kmsSahin wrote:I done both sides in 25 minutes which included taking the wheel off and jacking it up
Takes about 10,000 limiter bashes.
Just pop a brick on the accelerator and head inside for a cuppa and you should be good to goDaniel2019 wrote:Gotta run the engine in mate.silverGPX wrote:Getting around to modding at 250,000kmsSahin wrote:I done both sides in 25 minutes which included taking the wheel off and jacking it up
- shadowarrior
- Tightarse
http://imgur.com/a/Ugq8Y/all
Too much camber and toe, and too high...so need to fix all of that tomorrow. Can you adjust ride height with unsprung weight? Or should I remove the bottom bolt of the shock assembly and then adjust it?
lol does a 15.2 down the straight and what was your best? LolsilverGPX wrote:Getting around to modding at 250,000kmsSahin wrote:I done both sides in 25 minutes which included taking the wheel off and jacking it up
Only cos of no fuel and no weight lol!
I had a full tank! f**k ya
Keen for a rematch when u get back, mighty car mods style, you're gonna get chopped!
I'll borrow go pros from Joseph haha
- shadowarrior
- Tightarse
Its a suspension thread ffs!!!
Just cos you're a suspension noob sidds
- shadowarrior
- Tightarse
Doesn't matter, this still isn't the screen play section for Brokeback Mountain.
- shadowarrior
- Tightarse
Do I need adjustable front droplinks if I want to play around with ride height via the coilovers on the pre-facelift GPX? Damn droplinks connect to the shock instead of the control arm... :\
Trying to justify $170 adjustable front droplinks from Whiteline vs $50 normal ones from ebay.
- ZFL45H1
Im running normal seems ok havent got any problems
- shadowarrior
- Tightarse
Have you lowered your car with the BC coil overs? Normal ones from ebay?ZFL45H1 wrote:Im running normal seems ok havent got any problems
