Envy Imports Dyno Day
- aza013
- NSW Coordinator
Re: Envy Imports Dyno Day
About 20'000K's ago.
Well it should be fine then. What about when you had that sh*t fuel in your car, did they clean the filter on the fuel pump? Only other suggestions I can offer without knowing anything else is check plugs, leads, air filter, exhaust.
- aza013
- NSW Coordinator
Yep every thing was cleaned/ flushed, changed and all that good stuff when she went down due to the fuel.I8A4RE wrote:Well it should be fine then. What about when you had that sh*t fuel in your car, did they clean the filter on the fuel pump? Only other suggestions I can offer without knowing anything else is check plugs, leads, air filter, exhaust.
I have to check the air filter and I know that the exhaust needs doing as it's still the factory one.
WHAT!!! you were getting 137kw on factory exhaust???
- aza013
- NSW Coordinator
Yep just a supper high flow cat and changed out the back muffler is all that has been done
Factory headers, pipes and two resignators still in place.
wow,, nice. Well I doubt it is the exhaust then.
- aza013
- NSW Coordinator
And just think what it could be if I did upgrade the exhaust system
But befor I do any more on this set up I will see if I get the green light on what I want to do.
If I get the green then this engine gear box and maybe haltech will be up for grabs
But it would have to be the right price for it to be sold due to the work it has had done to it.
- zuihoujueding
good luck mate, yours a benchmark for all NA FTOs.
- koolio1234
Aza, Did you end up fixing that rich mixture your were having a while back? Might explain the lower figure
- Kustom
I know... only 100 odd more kws than youKustom_FTO wrote:FFS ben. Fail.
Checked your fuel filter recently?
- Tippin
hopefully you will get better fuel consumption now...
the lower outlet on mine was bent like that as well, now i get why my car was jerking so badly when i accelerated on low fuel
- Kustom
Nope.Bennoz wrote:I know... only 100 odd more kws than youKustom_FTO wrote:FFS ben. Fail.
- koolio1234
also millions more torxBennoz wrote:I know... only 100 odd more kws than youKustom_FTO wrote:FFS ben. Fail.
Should have seen the back pressure that pissed out of it when I cracked the lower nut. Allll over the hot exhaust it went
Yep, fuel economy now seems much better. Also the random stalling problem I had is now gone as you'd imagine!
Sounds like I'll definitely have to change the RVRs then.Bennoz wrote:Yep, fuel economy now seems much better. Also the random stalling problem I had is now gone as you'd imagine!
Right royal pest to get too.
WIN!!Bennoz wrote:Should have seen the back pressure that pissed out of it when I cracked the lower nut. Allll over the hot exhaust it went
Since changing to bigger injectors, my fuel consumption has gone out the window. I am only gettin about 450kms a tank and thats driving like a granny.
- rock_it
Ohhh man .. I ain't even going to go there ...Bennoz wrote:Should have seen the back pressure that pissed out of it when I cracked the lower nut.
fkn ahahahahahahahahaharock_it wrote:Ohhh man .. I ain't even going to go there ...Bennoz wrote:Should have seen the back pressure that pissed out of it when I cracked the lower nut.
Thats f**ken 'pop-nad.' A whole different scenario... but worded the same
You know, like when you just on your bike awkwardly?
