Could be..
I've got a spare if you wanted to test it.
4000 rpm
- Dave1971
Re: 4000 rpm
Thanks for the offer, but am on the other side of the world..Bennoz wrote:Could be..
Re: 4000 rpm
Dave, see if Don (RedGPX) or S&S spares on FTOOC have got spare knock sensors for you to try.
- payaya
Re: 4000 rpm
Does your engine check light work when you first turn your car on? If not check the bulb.
Check the output voltage of your TPS. Should see 4.5 - 5 volts at what.
- Dave1971
Re: 4000 rpm
Yes the check light works when i switch it one, where should i see the voltage on what wires ?payaya wrote:Does your engine check light work when you first turn your car on? If not check the bulb.
- payaya
Re: 4000 rpm
http://www.3si.org/wiki/index.php/TPS_T ... AdjustmentDave1971 wrote:Yes the check light works when i switch it one, where should i see the voltage on what wires ?payaya wrote:Does your engine check light work when you first turn your car on? If not check the bulb.
But the FTO TPS wires are the exact opposite to the above guide.
