Installing clutch pedal
Re: Installing clutch pedal
I meant to say "yeah same as brake fluid" (Dot 4)
Sahin wrote:I meant to say "yeah same as brake fluid" (Dot 4)
Sweet
That'll dodestinationtoby wrote:Bennoz wrote:Got oil in the gearbox?
Auto one recommended this one . Figured it will do for now? Is suitable? http://www.penriteoil.com.au/products.p ... oducts=375
- Shane001
When I first bought the racecar I put Penrite in it, not sure if it was that particular oil, drained it again after 1 practice day at Oran Park and there were tiny specs of brass through it. Great oil if you want to destroy your synchros.destinationtoby wrote:Auto one recommended this one . Figured it will do for now? Is suitable? http://www.penriteoil.com.au/products.p ... oducts=375Bennoz wrote:Got oil in the gearbox?
OhShane001 wrote:When I first bought the racecar I put Penrite in it, not sure if it was that particular oil, drained it again after 1 practice day at Oran Park and there were tiny specs of brass through it. Great oil if you want to destroy your synchros.destinationtoby wrote:Auto one recommended this one . Figured it will do for now? Is suitable? http://www.penriteoil.com.au/products.p ... oducts=375Bennoz wrote:Got oil in the gearbox?
So what do u recommend? Doesn't seem to be much to choose from..
Shhhh Shane... you'll blow my cover
I used this.....is going pretty good....no issues....
- Castrol.jpg (50.78 KiB) Viewed 400 times
Which shane is the question :OBennoz wrote:Shhhh Shane... you'll blow my cover
PHIL069 wrote:I used this.....is going pretty good....no issues....
The one that's spelt correctly.Sahin wrote:Which shane is the question :OBennoz wrote:Shhhh Shane... you'll blow my cover
Fkn Shaiiyahhnneee.Astron_Boy wrote:The one that's spelt correctly.Sahin wrote:Which shane is the question :OBennoz wrote:Shhhh Shane... you'll blow my cover
- Shane001
so what do i do with these plugs now? just cut em off?
- vipfto
Yeah. Assume you joined two thicker wires for neutral safety switch and got reverse light switch sorted the rest are not required. Can also remove auto ecu from inside
Awesome.vipfto wrote:Yeah. Assume you joined two thicker wires for neutral safety switch and got reverse light switch sorted the rest are not required. Can also remove auto ecu from inside
Is something ment to plug into there?
- Shane001
Astron_Boy wrote:*shrug* Diagnostic port?
Shane001 wrote:Astron_Boy wrote:*shrug* Diagnostic port?
Well, you never know.
I like guessing, especially when it turns out to be right.
