When I put my car in gear (manual), I can shake the gear stick around, side-to-side. It dosen't effect the car in gear, just makes changing gears less smooth. I'm making an assumption that there are some bushes - rubber or otherwise - around the linkages under the center console. Can anyone provide me any info on this? Or does anyone know what I need to replace (part numbers?) and where I could source these parts?
Yeah, there's a couple of nylon 'cups' that snap on the vertical & horizonal pivots points of the stick itself. I'll dig up the numbers from CAPS tonight. I think there might also be a few other little plastic bits in there that wear - I'll pop up the diagram as well
Its still bugging me a bit thou mate... I coulda sworn there was another one in there. Im also thinking there could be a nylon roller type bearing in the end of one of the cables I'll have a look at mine today.
