Supercharging a v6
- manofwood
Supercharging a v6
how hard do you think it would be to supercharge a mivec v6?
i was pondering a custom manifold with a charger off of a cooper S, seeing as they're east west FWD, or even an SC14 off the 1GGZE. if you chopped the the top off the manifold and shortened the runners to make it fit, and added sufficient/ relevant fuel & computer bits, could it work? or have a distant mount, or centrifugal type charger with an appropriately sized belt?
i'm getting a bit tired of seeing how severely limited the FTO is in the aftermarket world...
- bigpitty1
I have done some measuring with a raptor supercharger, I was going to get rid of the AC and have the supercharger sit where the AC compressor was, It didn't fit in real well, but I reacon a ROTREX supercharger would have more luck fitting in.
Bennoz has a Project where he is fitting a Eaton supercharger.
- BorepYano
ben is the one u want to talk to about that, and there's a thread on his progress.... or lack of progress lately on it... i think its in this section (too lazy to look now), search for it
- RichardB
- Storm
'charger manufacturers will tell you that an intercooler isn't needed as the air isn't running past a red hot turbo and manifold but compressing air will still heat it up. For low boost I suppose its up to yourself.
If it would fit then a ROTREX one like I suggested retails here at £1250 plus VAT with a further £60 for an oil cooler for it. For that you get the charger and its own lubrication system.
It works out at around £1540 and then you need to make up a custom bracket (they tell you how to do it) and sort out fuelling and pipework.
No worrys about turbo up pipes or melting anything with a hot turbo.
See http://www.rotrex.com for further info.
- Delvance
For an fto... you'll most likely find turbo would be the cheaper and easier option. There's more turbo guys out there to ask for advice and a couple of workshops will have some experience with them. S/c'ing will be hard as no one has a recipe yet (in aus anyways i think), meaning you'll have to experience and probably waste a fair amount of money.
That said, s/c would generally make a more driveable and predictable car with it's linear power and torque curves. Oh, and s/c belt slip sucks.
Do most of us really need that much more power though ? A light/moderate tuned fto is fairly fast (still faster than most hot hatches and able to keep up with some stock turbos) and it already torque steers pretty ugly... Big power at front wheels will make for a less enjoyable daily driver.
- FtoSam
^^^ what he said... torque steer is your enemy..
Since i turbo'd mine, i've been contemplating buying a cheap GPX for handling... the turbo will always be slower around the twisties which are ultimately the funnest part.
S/C i would presume would have some bigger traction issues as you get a whole lot more power down low. where as a turbo builds up to it.
do your research... and then do up a costing... then double it... that is now your budget... you may still go over...
my first costing... $6k...
Im on about $18k now...
- manofwood
That setup ^^ has also been done on a 6A12 galant.
If you want to read up on how I've done it, its in here:
http://www.ftoaustralia.com/modules.php ... pic&t=5778
I thought about that sort of setup above, but those types of blower are 3 grand out of the box. You also have all that plumbing to content with. I thought why not go for the throat & just slice up the intake manifold, weld up a plenum & just bolt the bastard straight on.
I got it to work on one motor, but some pulley miscalculations saw far to much poundage go in & I blew 2 rods outta the block.
Im doing the same thing now, but better thought out. We are bolting an Eaton M45 blower ($300 off ebay thank you very much) direct onto the manifold. Cut all the runners & rubbish out & have it feed direct into the cylinders. TB mounts to the back of the blower & all's you need is a piggy back to add the extra juice. Although I'll never get the dizzying highs of a turbo on full boost due to the blower sucking power from the drive train, I will get something that starts every day & pulls hard from the word go - no turbo lag. If I get 160Kws out of it at the wheels I'll be happy... that enough to get the pesky Rexes & Soap Boxes off my arse.
- FtoSam
lol... only 160kw...
i had 148 or something and it was pretty nuts... smoked my standard clutch in a week... lol...
I so wanna see a supercharged FTO... would sound soooo sexy...
ben hurry up and finish... when u do im comin to sydney...
race day? Qtr mile then track? (yes you'll nail me on both i know)
- aza013
- NSW Coordinator
- BorepYano
- FtoSam
- SG
you wont get tyre smoke and understeer if the car is set up right and you drive it properly lsd would be worth its weight in gold aswell..
...also u should be able to get the power down even better with an upgraded front ARB because the ARB puts more pressure on the ouside tyre as you turn and thats the tyre the lsd is mostly driving as you accelerate out of the corner... just have to raise or lower the rear or something to get the cars balance back for mid corner depending on what u've got.
...*goes back to his corner*
- manofwood
