Internal wastegate
Internal wastegate
I think the turbo i brought has a 9psi internal wastegate and i need to lower this to run around the 5 psi mark anyone know how to do achieve this. Id rather not have to run a external wastegate if possible
Thanks Simon
Thanks Simon
- FtoSam
Cheers buddy
- jonowong
no no no no!!!
f**k!
u just twist a nut to adjust the boost!
http://www.saab9000.com/procedures/exha ... stadj.html
f**k!
Garret turbos dont have that nut... well atleast mine doesnt
Same questions how old is it, what model (is a deceptor pro) etceThix wrote:found a BOV for $50, i'm getting pics and more info on it soon.
its a "GFB (go fast bits) BOV sounds like a turbosmart VEEPORT and fits the same"
Its $50 you want it?
I have made an offer on another one waiting to hear back from him on friday
that would depend on the tune wouldnt it?
- jonowong
- Delvance
What do you think i'm an idiot ethix ?
Just get a 50/50 bov, you can have a decent sounding bov (if you're into that) and still not get afterfire/poppy exhaust and also get the performance benefit of recirc (somewhat). In saying that, recirc and atmo doesn't provide a huge performance increase...it's hardly anything lol.
- khunjeng
use a valve which recirculates the vented charge, unless you've using a blow-through MAF, which sits in the IC plumbing, somewhere between the compressor and the throttle body.Delvance wrote:What do you think i'm an idiot ethix ?
Even these so-called "hybrid" valves - they still cause you to lose some of your pre-metered air. So why even bother with them? People think that the valves are analagous to the OEM valves (which recirculate 100% of the charge), while in fact they are not.
Venting any of your pre-metered intake charge to atmosphere isn't the smartest thing to do.
IN addition between gears it will run rich, why is this bad...clogs up sh*t in the long run - why bother.
- Delvance
Ay Khunjeng, i knew all of that.
In addition to your suggestions, depending on your car you may be able to get a piggyback ecu controller that actually shuts off the injectors during shifts which prevents the running rich when the bov vents.
Personally, i'm running the HKS ssqv v2 atm, switchable between full vent or full recirculate. I'm happy with it![Smile :)](./images/smilies/icon_smile.gif)
