bottom end (connecting rod pic request)
J
Post by J »
are there any differences in the GR and GPX bottom end.
i need a replacement crankshaft and connecting rod as mine are getting worn out (check for WTB section) and need to know if i can get one from a gpx.
id be sure they are identical its just heads that are different on gpx/gr
Cranks take a lot of punishment before needing to be replaced. Normally you have the journals machined & you buy oversize replacement bearing shells from Mitsi to suit the machined journals.
Rods dont wear out either... unless you bend them.
J
Post by J »
i got the bearing replaced already which they machined if thats what your talking about ben.
but because they couldnt get a crankshaft and connecting rod <- which they said had been bent, i hear soft rattles above 3000rpm on all gears.
can anyone confirm alongside 'Vipfto' that the crankshafts are the same?
Nasty!
Yeah, they're the same.
J
Post by J »
i need a picture of the connecting rod if anyone has one so i can send it to a few people.
and to make sure the part circled in red is the crankshaft yes?
Image ref - camskill
thats the crank, pity im not back in NZ i could then give you any pic of bottem end part you need :roll:
Have a look in this post and let me know what you need.
http://www.ftoaustralia.com/modules.php ... ic&t=13232
