Nice craig.
Same deal for lights have to bake them?
vipfto wrote:Nice craig.
Nah.. Less fuss.. Replacement units.. So pull out, put in, wire up HID's..
Those are mint. Should get a photo shoot done of this car
Scorpionwally8
Post by Scorpionwally8 »
Sprayed the first base coat on my side skirts
bjk wrote:Those are mint.
Look like headlights to me..
Lawl! :lol:
Smartass. :tongue:
MaxD
Post by MaxD »
Derusted all the metalwork behind the facelift bumper on Tuesday. Wednesday applied a rust converter which cures to form a coat of primer. Yesterday applied the 2nd primer coat in red oxide. In 48hrs or so, the final gloss coat will go on and no one will ever see it!
So since my factory coil packs were failing at 200kw I made up a COP kit and got some Denso VK22 plugs.
No HEC 716s?
Aren't they discontinued?
And these do fit right in. Just had to buy the connectors and make up the wiring. Plugs into the factory loom.
How are you going to mount them on the back valve cover?
fraz91
Hair-do
Post by fraz91 »
Started modifying the new toy. Fitted a set of 4mm spacers front and rear, and stickers on the left rear quarter and rear windscreen. Taking her out this arvo for a few pics and maybe another cheap mod
Sent from my SM-G920I using Tapatalk
fraz91 wrote:Started modifying the new toy. Fitted a set of 4mm spacers front and rear, and stickers on the left rear quarter and rear windscreen. Taking her out this arvo for a few pics and maybe another cheap mod
JB4? :tongue:
fraz91
Hair-do
Post by fraz91 »
JB4? :tongue:
Maybe later... [WINKING FACE]
JB4 is amazing well worth the coin
Sent from my SM-G930F using Tapatalk
Moused
Post by Moused »
Changed out the oil, trans fluid and plugs today..
The back ones were interesting, not as hard as I expected.
Learnt why I keep losing oil, but... Oil in 2 of the plug wells, woo! :roll:
This has been sitting on my bench for about a year now. Time to finish it off.
Dras
Post by Dras »
Oil and filter change with the help of my 2 sons.
Admittedly it is only 1/2 done has they had to go down for a nap.
Websta14
Post by Websta14 »
Put in a new fuel filter then ended up snapping the connected from radiator to fire wall so now have to bypas that and go back into engine :(
Degreaser the underbody and engine bay (with a toothbrush in some parts!) lol
Adjusted the timing belt and changed the oil!:)
