GPX TURBO :D
GPX TURBO :D
Few Questions.
I have access to a FREE Low km's TD04, intercooler, BOV.
Im not going to run anymore than 7-8psi.
Ive got an exhaust shop less than a half a kay away, who said he can make me up anything i want.
All i want to know is should i lower the compression, do i need a new fuel pump and/or injectors?
What ECU/Piggyback ECU do you reccommend. Should i get a mivec controller? or is that controlled by the aftermarket ECU?
Is a Galant oil pump a good idea for the oil starvation in the heads?
Am i better off running mivec at 500rpm so theres no headaches with tuning or setting it up for 4500rpm to spool the turbo quick?
Re: GPX TURBO :D
oh and ill be getting a fuel pressure regulator and that uprated fuel pump from camskill.
- vipfto
Re: GPX TURBO :D
new pump and larger injectors will help but think they will handle 5 psi nicely
Try haltech tried and proven and many tuners in aus
Pretty sure galant pump is same (6a12 series) most likely a 6A13 would suit better
You can set the mivec however you want with piggy back ecu tuning for that should be fairly easy
Basically I would just do the turbo first run @ 5psi for a while then up it slightly, If it all goes bang its bugger all to replace motor as you already have piping etc ready to go wont have to pay for whole conversion again
Re: GPX TURBO :D
my mates got a fuel rail and injectors off a gsr would they fit and i just get two more?
okay 6a13 oil pump it is. Does it need tuning or just pumps it thru quicker?
And will be 2.5 inch exhaust be alright?
Re: GPX TURBO :D
I have to pull the engine down too, for the blown headgasket, i really need to know about a decompression gasket, is it nessacary?
- spency
Re: GPX TURBO :D
Ask Sam. He'll tell you about decompression plate.
- Kustom
Re: GPX TURBO :D
Preety sure you will have to do. As to your mivec controller, it will be controlled through your ECU. And to your next question, I think you'd be better of going with Haltech.
Re: GPX TURBO :D
Well doing the decompression plate is a pretty big deal because lowering the compression will make my car gutless so i will definetly have to turbo it.
- Kustom
Re: GPX TURBO :D
And I think you'd need your exhaust to go 3" if you turboing
Re: GPX TURBO :D
Nah i dont want to as of yet, it seems to flow pretty well as it is.
I want it to be turboed first and able to run.
Would the Haltech interceptor platinum be suitable for this application??
- spency
Re: GPX TURBO :D
3" all the way through?
i'm interested in all the turbo talk as i'm looking for a GR engine or somebody thats turboing a gpx engine to see what i'm up for.
gunna buy a bike as a daily commute to take the fto off the road for 2-3 months
Re: GPX TURBO :D
Yeah its good for me cos im losing my license for 6 months, im buying a cressida as a daily when i get off the suspension. for pretty cheap daily.
So im not too worried. I just want to make sure i have all the right parts before i do anything. And ive already started off with the right turbo and intercooler for free.
- Kustom
Re: GPX TURBO :D
Yeh I believe the Haltech Interceptor Platinum will be a good choice, but gonna need to run it by bennoz/simon first.
Take your time buying the items and wait for the right price bro to keep the prices down.
Re: GPX TURBO :D
Ok, here's your parts list with ballpark figures:
Full gasket kit, inc head gaskets & seals (and if you decompress with plates you'll need 4 head gaskets) - last price I saw on these was around $400
Timing belt, tensioners (would do this as a matter of course) - $250
Water pump (would do this as a matter of course) - $100
Fuel pump (Walbro in-tank 255l/h) - $150
Sard FPR - $200
6A13 injectors - $400
6A13 oil pump - $200
3inch exhaust with high flow cat, resonator & muffler - $1000
If you want good headers buy an RPW or hurricane set - $500
Custom piping inc dumps etc from headers mated to turbo & exhaust - $500
Haltech Interceptor (with install & tune) - $1500
Sundry Item (filters, fluids, gasket goos etc etc) - $200
So there's $5200 - then add labour for the things you cant do.
Then there's things you haven't mentioned yet:
Clutch to hold all this power - $400 (plus or minus labour to remove & reinstall the box)
Brakes to haul it up - $500 (for say, slotted rotors, good quality pads and a dot 5 fluid flush)
Personally, I wouldn't bother with a Mivec engine, I'd go buy an old non mivec dunger & do all this to it.
The whole Mivec system was specifically designed to give more power on Naturally Aspirated engines - not turbos.
All the f**king around you'll run into trying to set mivec kick in points vs spool up & tuning it all together
will be a nightmare. Plus, if you went non mivec, you could theorectically use 6A13 cams - a profile designed
for turbo. In fact, all these 6A13 bits your using, may as well buy the whole damn 6A13 engine!
Sard FPR - $200
Re: GPX TURBO :D
All i want to know is should i lower the compression, do i need a new fuel pump and/or injectors? - Yes, your going to have the head off so why not. Yes you will need a new pump and injectors
What ECU/Piggyback ECU do you reccommend. Should i get a mivec controller? or is that controlled by the aftermarket ECU? Haltech Platnium for sure. No dont worry about a mivec controller
Is a Galant oil pump a good idea for the oil starvation in the heads? You need to do more research, oil starvation is BS comes down to crappy workmanship
Am i better off running mivec at 500rpm so theres no headaches with tuning or setting it up for 4500rpm to spool the turbo quick?Talk to APC in underwood the are always tuning mivecs
Turbo is a completly different kettle of fish. What "flows nicely" for a N/A is completely different to what "flows nicely" for a trubo. DO A 3" inch exhaustsilverGPX wrote:Nah i dont want to as of yet, it seems to flow pretty well as it is.
- Kustom
Re: GPX TURBO :D
I wish it was as simple as puting the engine in and that was it
Re: GPX TURBO :D
why do i need a sard fpr? surely there is a cheaper brand.
cant i use magna injectors? or the RPW ones?
can i just use an ecu pinout diagram to wire it in myself?
Just went and talked to my exhaust guy, he can do a 3" dumppipe and we looked at my system as of now and i have a 2.5 inch exhaust right up to just before the muffler then it steps up to 3". So all i need is 3" cat, piping and resonator. He said he can do up pipes and intercooler piping as well.
i also have 10000KM old front rotors with ebc reds, freshly machined rear rotors with brand new soft pads. i have a heavy duty clutch replaced only 40000KM ago.
I also already have performance extractors.
Re: GPX TURBO :D
Okay turns out i dont have a blown headgasket after i blasted the crap out of my radiator for several hours with water and compressed air. Sits colder than it ever has before.
I still want to do this though.
- AJ
Re: GPX TURBO :D
I got quoted $3k. Where do I get it for $1500?Bennoz wrote: Haltech Interceptor (with install & tune) - $1500
- spency
Re: GPX TURBO :D
Deposit your moneys into the Bank of Nigeria, they will sort the rest out.AJ wrote:I got quoted $3k. Where do I get it for $1500?Bennoz wrote: Haltech Interceptor (with install & tune) - $1500
