Epileptic FTO
- bass_twitch
Epileptic FTO
Ok so I have had enough..
I've spent waayy too much and I'm not getting anywhere with this problem.
Problem:
I am getting steering wheel shake at anything over 80km/hr. (and sometimes at lower speeds).
Also the steering wheel will often throw me all over the road whenever it is a bumpy road and tries to fight me all the time as soon as I get a bit of speed.
Also my car is 'clunky' over bumps/ there is a rattling in the steering wheel.
Now you may be saying "easy, just get a balance or maybe you have buckled wheels".
Let me tell you what I have done to fix this motherfarthin' issue:
- 4 x new mags (with 4 x used tires)
- Steering rack reco (as it apparently needed to be done.. I paid an arm and a leg and it honestly doesn't feel much better nor did if fix my issue - going to abuse my mechanic this week. I'm not impressed).
- Obviously a wheel balance was done with the new wheels (it has had 3 in the last month now).
- A wheel alignment (because after the rack was done it needed an alignment - it has had 2 in the last month and a half now).
- replaced front 'd-links'.
Now according to my 'mechanic' the front drivers control arm bracket is also screwed. He didn't fix it last time I put the car in because.... I don't know why actually.
Now I have no idea what the front drivers control arm bracket is! (I can guess, but no idea really).
Soooo
Overall I have had jack and I'm just wondering if the control arm bracket being screwed could make all these problems or where else should I be looking. If I don't get any progess within the next 3 weeks (i.e. 2 pay weeks) the car is going to MEEK. apparently they might know what they are doing with an import mitsubishi.
End vent/rant.
Problem:
Soooo
End vent/rant.
Re: Epileptic FTO
Are your shocks loose?
- bass_twitch
Re: Epileptic FTO
no idea.. how would I check? (at the strut tops)silverGPX wrote:Are your shocks loose?
Re: Epileptic FTO
Yep tighten those. Take the wheel off check the two bolts are tightened on the lower shock mounts.
- rock_it
Re: Epileptic FTO
Yeah.. MEEK are good blokes.. And definately Evo specialists.. And the set up is pretty much the same..
Are they close to u?
If not, my mechanic at Peakhurst would be able to settle the problem..
- bass_twitch
Re: Epileptic FTO
Yeh Girraween isn't too far from where I am. Might give them a call this week then.rock_it wrote:Yeah.. MEEK are good blokes.. And definately Evo specialists.. And the set up is pretty much the same..
Are they close to you?
Hmm sounds like simple, I'll check it tomorrow if I get a chancesilverGPX wrote:Yep tighten those. Take the wheel off check the two bolts are tightened on the lower shock mounts.
- -Nighthawk-
Re: Epileptic FTO
I have the same problem with my steering turning to the left and trainlining all over the road when it's bumpy.
So would the first point be to tighten the shocks do you think?
- Gholdwayne
Re: Epileptic FTO
Brendon, i'll contribute my 2c, i had a little hiccup too with my steering system before, like it vibrates and it gets faster as the car goes faster, turns out, my tyres were egged - one spot was protruding, and on the other side, there was a flat spot
and this was when the car was off the road for about a month. Funnily though, it was only the 2 front tyres. - Try to jack the car up and spin the wheels by hand, look at one position of the tread while doing so, and see if the tyres are perfectly round.
As for clunking, obviously rubber doesn't do that, same with the rattling, so, got no contribution there but i'll be wishing you luck with that - frustration of these things get us so depressed...
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
FTO[For The Orgasm]
Re: Epileptic FTO
If the steering is shaking after you replaced all 4 rims then clearly you have a warped brake rotor(s). Either get them machined or replace them.
As for a bent "front drivers control arm bracket" thats a worry if true, as there is no bracket. Its part of the subframe where the control arm bolts up to...
I'd be simply replacing all front bushes. Sway bar to chassis bushes (D bushes,) lower control arm front bushes & lower control arm rear bushes... and thats it, there are only 3 different bushes up there.
The only other thing that could cause issue is worn / cracked rubber strut tops (which are visible from the engine bay where your strut brace goes) or if you've snapped your swaybar or bent a swaybar link (drop link.) Have you or the previous owner ever under steered the car into a gutter?
- bass_twitch
Re: Epileptic FTO
I replaced the rotors only 8 months ago to RDA slotted... so I don't think that is the issue..Bennoz wrote:If the steering is shaking after you replaced all 4 rims then clearly you have a warped brake rotor(s). Either get them machined or replace them.
I'm thinking maybe tie rod ends or something..
I have sent MEEK an email, hopefully they'l get back to me tomorrow.
I will check the strut tops (I think they are fine though), and I'm not sure if previous owners have understeered into a gutter - it did have at least one buckled wheel when I got it... so that is definately a possibility.
Re: Epileptic FTO
Tie rod ends dont vibrate, they are stationary on the rack unless the ball joints in them are severely worn (never seen it on an FTO), further more they should have been swapped out as part of your streering rack reco.
Do you do any 'spirited' driving?
- bass_twitch
Re: Epileptic FTO
Short answer: yesBennoz wrote:Do you do any 'spirited' driving?
She gets driven rather hard at times..
But only within the speedlimits and in all constraints of the law :p
- Gholdwayne
Re: Epileptic FTO
Sames bahz!bass_twitch wrote:Short answer: yesBennoz wrote:Do you do any 'spirited' driving?
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
Re: Epileptic FTO
Yeah me too, so the disc rotors could well be warped
- bass_twitch
Re: Epileptic FTO
Even though they are only 8 months old...Bennoz wrote:Yeah me too, so the disc rotors could well be warped
Hmm.. well the car is probably going to be taken to MEEK late this week, so they are going to look at it for me.
They're an honest bunch of guys hey?
Because basically everyone has an idea on what is wrong, and every option is different!!
Here's hoping it is simple and not too much out of pocket!
- payaya
Re: Epileptic FTO
Serious? Both mine when and caused play in the ball joints.Bennoz wrote:Tie rod ends dont vibrate, they are stationary on the rack unless the ball joints in them are severely worn (never seen it on an FTO), further more they should have been swapped out as part of your streering rack reco.
- bass_twitch
Re: Epileptic FTO
No. Busted diffs are significantly more 'crunchy' than they are 'shuddery'
Re: Epileptic FTO
mmmmm crunchyBennoz wrote:No. Busted diffs are significantly more 'crunchy' than they are 'shuddery'
- Mmmm.jpg (30.56 KiB) Viewed 703 times
