Sahin's FTO
c0n13oX
Re: Sahin's FTO
Post by c0n13oX »
Got a link for where you got them?
Re: Sahin's FTO
c0n13oX
Re: Sahin's FTO
Post by c0n13oX »
Cheers!
Re: Sahin's FTO
Yup, same as mine and Bennoz and a few other people as well. Vinyl wrapped mine blue.
    Re: Sahin's FTO
    Yeah but I didn't have any trouble fitting up with no mods needed dwayne lol
    Re: Sahin's FTO
    Actually, I didnt have to mod it either. Im running stock bonnet and stock guards underneath too :P
      Re: Sahin's FTO
      Sahin wrote:Yeah it does, I even looked at bennoz' install before tackling this lol
      Oh and btw it's a f**king mission to install see by yourself! They are really hard to decompress by hand and bolt them up lol took all my strength
      Massive pain to get in right!
      Re: Sahin's FTO
      Yeah! Took me like 30 mins the first one and 5 the second lol
      Didn't have to do a workout today
      Re: Sahin's FTO
      dstocks wrote:Actually, I didnt have to mod it either. Im running stock bonnet and stock guards underneath too :P
      You drilled a new hole in your bracket and cut the excess off didn't you?
      Re: Sahin's FTO
      They werent hard to fit. 10 minutes for both. Ive taken them off and put them back on a number of times now. The trick is to lift the bonnet as high as possible (higher than the bonnet stand)
        Re: Sahin's FTO
        Yeah but you modified yours! Lol I didn't have to
        Re: Sahin's FTO
        Wow... vixens took 5 mins tops for both... spent longer painting the brackets.... what was the bitch part?
        Re: Sahin's FTO
        Compressing them! Lol it's like putting a top hat on without spring compressors lol
        Re: Sahin's FTO
        Sahin wrote:Still on my ps till august so I'm saving for a wolf v550 plug in ecu now so Its an easy install and in the meantime gotta do a few little things before then like relocate battery to boot and I could probably set the oil cooler up now too. Probably even the w2a inter cooler setup aswell
        This will be mad if u go ahead with it all, havnt seen anyone turbo an FTO since I've been on the forum.
        How much boost r u gonna run? Have ya got estimated cost on getting the whole thing being finished inc injectors bigger pump ? ecu & tune etc??
        What can the engine handle with standard internals?
        Just run 20pound and f**king thrash it at the drags
        Re: Sahin's FTO
        I've got the injectors already (560cc)
        Costs to come are
        255 fuel pump $100-$200
        Relocate battery $100
        Brand new plug in Ecu plus tune $2100
        Few silicone pipes and clamps and lines and fittings $150
        I really don't have to get a brand new ecu but I am because I can't be fucked getting a used one for it to f**k up on me and I'm getting a plug in one for ease
        The engine can handle 6psi easily so that's what I'll run while probably building the spare one I have up to handle more
        Gearbox rebuild on the spare gearbox on the cards too if bennoz is up for it, and if I do that I'll chuck a wavetrac LSD in it
        Re: Sahin's FTO
        You'll find it'll handle more boost than that, can safely run up 12 pound.
        Re: Sahin's FTO
        And do yourself a favor, grab some vernier cam gears. Only need 2 on the exhaust, there's 10kws in that alone. Also check out the fuel rail mods I've done upgrading the link between the 2 rails, part comes out of the US, fits a GTO from memory. You'll also need a decent fuel pressure reg, oh and a decent boost controller. There's another 5-600. Take that price list you've got above & double it!
        Re: Sahin's FTO
        Maybe he wants to run 6 so that he doesn't have to buy all the silly sh*t u just mentioned ;)
        Re: Sahin's FTO
        destinationtoby wrote:Maybe he wants to run 6 so that he doesn't have to buy all the silly sh*t u just mentioned ;)
        Re: Sahin's FTO
        No matter what level of boost you want to start with, it is always best to prepare for the worst, or for higher levels, as one tends to get bored.
        When I built the Evo powered Sonata, I had lots of options to upgrade stuff for half the cost due to all being done at once... I was like, nah, I have the 1000cc bike for speed and fun, I just want this car to have a little more oomph ... After re-doing intercooler set-up, new turbo, bigger injectors, and even then rebuilding the engine as I could feel it was a little worn out...
        So do it all in one swoop ...
        That is why I have left the Evo/GSR go for so long as is... Just waiting for something to need a look at and then going with the long list... So from just fixing the radiator I have gone with: -
        PWR Radiator
        Adj Cam Gears (finally)
        New rocker cover with better connections for catch can (other one was slightly leaking)
        Software upgrade on the ECU (had to be sent to EMS)
        5 stud conversion (didn't really have to, but want the brakes ref below)
        GTO 4 pot brake upgrade
        Re-do turbo manifold (go from twin gates to single, and to fit the radiator)
        Dump pipes converted to ADR standard
        Bigger injectors - As will now be running flex fuel adapter
        When I looked at doing individual parts, it was a rather expensive list... So I thought I would save, do one, then go back, do another... But realised from my Sonata, that I will be paying double labour, and doing double effort. May as well take the whole thing apart, and put back together once... And properly at that...
        Also limits the amount of times the car has to come off the road, and the wasted rego...
        I also built the car when there was not such a crack down on modified cars. As the years have gone on, it has gotten worse, and now I have to go back and fix up all the short cuts that saved me a couple of hundred each at the time...
        /rant
