Located in Brisbane.
front is a freebie, you just need to remove it/pay for it to be removed, and I would encourage you to make a donation to Ben for hosting costs.
Rear is without the hole for rear wiper
- I'm swapping the one (with the rear wiper) from the shell to mine, so the one up for grabs is the one without the rear wiper. You can either pay the $65 I was quoted for removal or remove it for me and wait till I get them swapped around.
front needs to be claimed before the end of the month, rear needs to be done/gone by 16/08. Otherwise these are going to the wreckers with the shell.
PM or phone/sms O412 513 694
FS/freebie: Front & rear windscreen
- BorepYano
Re: FS/freebie: Front & rear windscreen
Hmm the front i was told is tricky, and is hard to remove without damaging, the rear however im not so sure.
Ill probably be interested in the front if it comes off in good nick.
- BorepYano
well, if you want it, then u'll have to take it out
This will help you take it out Taz.......
- Winow Breaker.jpg (21.54 KiB) Viewed 142 times
