At least I know where they work
![Cool 8)](./images/smilies/icon_cool.gif)
I'll go knock on the door for you scaredyObsidianRadio wrote:At least I know where they work
You're good at that, aren't you Phil?PHIL069 wrote:I'll go knock on the door for you scaredyObsidianRadio wrote:At least I know where they work
ObsidianRadio wrote:I got called back to the premises tomorrow for a second interview
...I'm going to ask who owns it and find them
ObsidianRadio wrote:...Do you just casually walk into businesses to see who owns the FTO you see parked out the front?
This is the most random thing I've seen in days LOL
There's a difference between us, Phil... I have A REASON TO BE THERE.PHIL069 wrote:ObsidianRadio wrote:I got called back to the premises tomorrow for a second interview
...I'm going to ask who owns it and find themObsidianRadio wrote:...Do you just casually walk into businesses to see who owns the FTO you see parked out the front?
wait till your marriedBennoz wrote:And this dual quoting from separate threads thing is very feminine. Don't you abide by the man code? Anything a man says is null & void after seven days & can no longer be used in an argument
Flol so trueSchumieFan wrote:wait till your marriedBennoz wrote:And this dual quoting from separate threads thing is very feminine. Don't you abide by the man code? Anything a man says is null & void after seven days & can no longer be used in an argument![]()
Yes, I know the rule, I abide by the code but...........................it doesn't count when you're dealing with ObsidianRadioBennoz wrote:And this dual quoting from separate threads thing is very feminine. Don't you abide by the man code? Anything a man says is null & void after seven days & can no longer be used in an argument
PHIL069 wrote:Yes, I know the rule, I abide by the code but...........................it doesn't count when you're dealing with ObsidianRadioBennoz wrote:And this dual quoting from separate threads thing is very feminine. Don't you abide by the man code? Anything a man says is null & void after seven days & can no longer be used in an argument
