Worthwhile buying a press?
- Shhtuart
Super cheap sells the 3000lb workshop press for $150.
Would anyone recommend buying this and doing it myself over taking the suspension apart myself and getting a shop to press them in and out?
I'm in no rush to change the bushes, but they will need doing soon.
Re: Worthwhile buying a press?
That's the one bennoz has and he does his bush pressing himself
It's a bit of a fiddly job if you're not used to it, but it is well worth it.
For $150, like Bennoz, you could press one out.
- vipfto
Great investment if you do enough work to warrant one
If he was in your state, you'd be telling him to get it.vipfto wrote:Great investment if you do enough work to warrant one
- vipfto
The only thing I find annoying about them is the size. They're physically too small to get large components into. I have to come up with all sorts of fancy jigs to get everything done that I need.
- Shhtuart
So would it be sufficient for all suspension bushes?
- -Nighthawk-
Yes, I would highly recommend you get one! :p
-Nighthawk- wrote:Yes, I would highly recommend you get one! :p
- Shhtuart
Haha DIY Day: Bushes Edition.-Nighthawk- wrote:Yes, I would highly recommend you get one! :p
- -Nighthawk-
I like it! Charge $50 for entry and make up your money
- Shhtuart
I'll buy iy when it's on special next. I'll get an email from SCA when it's on.
- vanadinite
They're very useful tools, not just for suspension.
- ObsidianRadio
For $150, I wouldn't be complaining!!
^ Mankind has been asking itself this question since the start of time....I think you will even be able to find this question in the Holy Bible.
- payaya
Worthwhile? Maybe not sometimes, but there will come a time you will need one and if you don't you would be thinking why the hell don't I have them!!
Well I manage to bash out the spherical bearing's (sort of like a bush) on the rear end but getting them in was a different story.
If you are not planning on taking the items to be pressed out, I highly don't recommend trying to get pressed items out with a big hammer etc as it's a pain.
I've broken two vices trying to press in sh*t and it's not pretty when they break under load.
I got a 12 tonne one from Repco, its a taller unit than the sca one.
- Supplanter
- payaya
I dunno about 6 tonnes though, I was struggling with 12 tonnes pressing out the side mounts today. I was waiting for the big bang but fortunately didn't come.
Who presses them out? That a job for a drill bit & reciprocating saw. Bastards just fall out, then press new ones in.
