Where is the Tip drain plug
Was pretty wet today and was going to dump the transmission oil without jacking up the car, but couldnt see the drain plug. Can someone tell me where the drain plug is. (I know im lazy).
- bjk
- Totes
Re: Where is the Tip drain plug
I have a vague memory that there actually isn't one and it has to come out of one of the hoses...
Tim?
Tim?
- Moused
Here's mine:
21 or 22 from memory. Hopefully the pic gives you an idea of location..
Def easy enough to reach without jacking the car up.
OK, looks like its on the side on the outside.Isthat towards the frontor towards the back?
I'tll be the only 24mm bolt down there.
Getting too old.Need glasses...
And an A frame...
And an A frame...
- Moused
Welp, guess you can't drive then - I'll look after your cars, no worries.dstocks wrote:Getting too old.Need glasses...
And an A frame...
Dont think youd have the spaceMoused wrote:Welp, guess you can't drive then - I'll look after your cars, no worries.dstocks wrote:Getting too old.Need glasses...
And an A frame...
- Moused
Hey, that's my problem nowdstocks wrote:Dont think youd have the spaceMoused wrote:Welp, guess you can't drive then - I'll look after your cars, no worries.dstocks wrote:Getting too old.Need glasses...
And an A frame...
- bjk
- Totes
Nah, your problem is fighting me for them.Moused wrote:Hey, that's my problem nowdstocks wrote:Dont think youd have the spaceMoused wrote:Welp, guess you can't drive then - I'll look after your cars, no worries.dstocks wrote:Getting too old.Need glasses...
And an A frame...
- SchumieFan
Thanks Schumie, found it in the end
