Rear brakes
ARC
Rear brakes
Post by ARC »
Hey fellas,
I had my FTO rear discs machined down to minimum last week.
Thinking forward, I'd like to put in some DBA's, but they've removed them from the catalog.
I've found that the CH Lancer rear discs are 262mm quite close to FTO's 260mm rear discs.
DBA list the CH discs as DBA2203, has anyone here used these ?
I know it's only a 2mm difference, but I'd rather be safe than sorry.
Re: Rear brakes
I have a 2nd hand set of RDA slotted rear rotors on the shelf in the garage if you are happy enough with 2nd hand. They came off my FTO about 6 months ago when I puton a new matching set. Absolutely nothing wrong with them.
    ARC
    Re: Rear brakes
    Post by ARC »
    Thanks for the offer dstocks, but I may have a set of DBA's lined up already.
    Was just unsure whether or not to take them.
    Re: Rear brakes
    You should take them. DBA dont make them anymore (they are out of production), so you wont get them again.
      Re: Rear brakes
      There's a couple of RDAs still floating around on eBay: http://www.ebay.com.au/itm/DRILLED-SLOT ... 1303800700
      But correct on the DBAs. We actually ran the group buy that cleaned out the last of their stock. I picked up all the last sets from their Silverwater manufacturing & distribution centre.
      Re: Rear brakes
      Re: Rear brakes
      Give brakes direct a call they'll help you out
      Re: Rear brakes
      Supercheap has IBS or Protex rears.
      Brake Direct won't be able to help you with sh*t. They will promise they can..take your money...sit on it...then say ooops sorry, can't get your DBA, how about we sell you Protex?
      Re: Rear brakes
      They helped me out, ordered everything on the Friday and got the parts on the Tuesday. Maybe it's cos your black
      Re: Rear brakes
      silverGPX wrote:They helped me out, ordered everything on the Friday and got the parts on the Tuesday. Maybe it's cos your black
      Nah they helped you out because a c**t appreciates another c**t. You two c**nts should shake hands and share body fluids.
