Finally time time to let the old girl go. I've been keeping her as a backup car but it's not getting the use to make it worth the rego.
The Good
It runs
90% tread on tyres...
It's a Manual!
The Bad
Cam seals are gone spits out all the oil.
Front bushings gone..makes clunking noises.
The Ugly
Rust in roof
Paint condition is bad... real bad.. check out the pics
I don't recall the K's on it as I had the dash pod replaced by Joe & Riks and the working pod had higher k's.
I brought the car with 70k on clock pod failed at I think 120k, couldn't have added more than 60k as it was relegated to spare car at around that time.
It does run and is rego'd till end of next month I think.
Many of the new parts I added Clutch,Alternator sensors etc have had little use.
Also has a front bar tucked away somewhere.
Thanks!
<SOLD> 1995 FTO GPX MANUAL <SOLD>
- demonjay
- 20160610_154718.jpg (134.88 KiB) Viewed 1265 times
- 20160610_154801.jpg (138.29 KiB) Viewed 1265 times
- 20160610_154919.jpg (68.97 KiB) Viewed 1265 times
- 20160610_155019.jpg (105.98 KiB) Viewed 1265 times
- 20160610_155131.jpg (119.08 KiB) Viewed 1265 times
- 20160610_155202.jpg (164.59 KiB) Viewed 1265 times
Re: 1995 FTO GPX MANUAL $1000?? [QLD]
I'm interested in what the front bar is
- demonjay
- bjk
- Totes
That's a lip for prefacelift bar. Dcuatro.
I'd be keen on a few random bits if parted out.
Master cylinder, rear sway bar and control arms..
