Removing Gear shifter cable from bracket
- shadowarrior
- Tightarse
Ello lads!
Any guide/video/images/help/tips on disconnecting and connecting the gear shifter cable from the gear selector bracket when replacing said bracket?
- bjk
- Totes
Re: Removing Gear shifter cable from bracket
The clips are a bitch
The end
The end
- kiz
- SA Coordinator
Clips are a piece of cake if you use the right pliers hahahahbjk wrote:The clips are a bitch
The end
1998 Mitsubishi FTO GPVR AERO
Use your teeth
- bjk
- Totes
That's what she saidSahin wrote:Use your teeth
- shadowarrior
- Tightarse
Were you blowing a tranny bjk????bjk wrote:That's what she saidSahin wrote:Use your teeth
In other news.....a wild Sahin appears...... where the f**k you been?
- bjk
- Totes
Well there are strange noises possibly from a box...shadowarrior wrote:Were you blowing a tranny bjk????bjk wrote:That's what she saidSahin wrote:Use your teeth
Shady-Shane-o has been a-lurking, where have you been?
- shadowarrior
- Tightarse
Hah, I took a small break, back now... Save up all your $$ for group buys
Sent from my XT1572 using Tapatalk
Group buy: Shift Bracket
- bjk
- Totes
:utbnbrackets:Vectose wrote:Group buy: Shift Bracket
I watched your vids, Tight Wad. If you've got noise that goes away when you put your foot on the clutch, then I'm sorry to say you've got bigger problems than a tight wad bracket.
Start saving to pull the box.
inb4 "can I get away with just replacing the release bearing? "
This^Daniel2019 wrote:inb4 "can I get away with just replacing the release bearing? "
Or
"Can I replace the springs on the pressure plate?"
- BorepYano
that's what she said?Bennoz wrote:pull the box.
