Water/Oil Temp Gauges, cooked sensors
mezje
Post by mezje »
Got some gauges for free and looking at installing them this weekend...
Both the oil and water temp sensors seem identical but I'm not going to reuse them as they are very dodge. The sensor sits in a metal housing, whole unit looks similar to pic below:
Issue is the actual sensor that sits in the metal can just be pulled out on BOTH, someone has shoved white sealant in there to stop this but both just pop out, no seal at all.
I am going to get new sensors but will they work with the gauges? I'm under the impression this is not possible with an oil pressure sender but for temp I can imagine it would be ok...
The gauges are asia special cheapos
Re: Water/Oil Temp Gauges, cooked sensors
Same thing, needs to output the correct range.
Gauge is made to see a specific reading from sensor.
Just get some decent gauges. I've got a trade account with Rocket Industries if you want any Auto Meter gear cheap.
mezje
Post by mezje »
Bennoz wrote: Mon Aug 13, 2018 3:43 pm Just get some decent gauges. I've got a trade account with Rocket Industries if you want any Auto Meter gear cheap.
How much for water temp, oil and oil pressure?
These look good though and they were FREE :( :(
mezje wrote: Mon Aug 13, 2018 3:45 pm
There's one or two to choose from mate :lol:
https://shop.rocketindustries.com.au/se ... uct_page=1
Just grab the SKU number of what you want & I'll get you a quote.
mezje
Post by mezje »
Bennoz wrote: Mon Aug 13, 2018 3:43 pm There's one or two to choose from mate :lol:
"Wow this is a lot... Next Page (1 of 14)... Jesus"
Appreciate it, will take a look and shoot you a PM
So the sensor is just within a cap and makes no contact with the actual liquid?
Not sure why you need to change them.
Personally I'd get some conductive paste and put them back in there.
If/when they fail look at replacing them but it seems you are just complicating things for yourself currently
mezje
Post by mezje »
This is what they look like, gauge company seems to think they will be fine. Temperature sensors are pretty robust and oil pressure sender is new.
Yes, they're fine. It's how they work.
