fto boost limits
- bigpitty1
fto boost limits
turboing an fto I have heard is difficult but can be done and I have seen a few, supercharging I haven't seen yet, I want to how much all of you recon how much boost a fto can handle, I have seen Integra Type R DC5 with a jackson racing supercharger running at 9 psi and I hear that the Integra engine can handle about 10 psi with stock internals with a compression ratio at 11:1, isn't the FTO's compression ratio about a 10:1 so it should be able to handle 10psi without too much trouble.
I blew up a 6A12 block up 2 weeks ago on an engine dyno with 9psi running out of a sprintex blower. The more poundage (whether by turbo or supercharger) you put in - the LOWER you want your compression ratio.
I've now had decompression plates made to compensate & looks like forged internals are going to have to happen.
- Slither
If your looking at running stock internals i wouldn't go any higher than 7psi. Your looking at detonation problems after that and on hot days you'd probably be advised to run lower than that other wise you'll get pinging probs.
As for supercharging, you're probably looking at the same sort of costs as turbo charging. Main plus about supercharging is you should have much better throttle response but as yet no-one has been very successful at doing it!
- bigpitty1
- spetz
if we're playing that game go VR4 4x4. As for turbo vs. Supercharged my guess is the 2l wont take the SC power and the turbos dont fit too well, go NOS for traffic lights and remember how much all that extra petrol will cost!
I too, am slightly Australian. <br>"You flamming galah!" <br>
Is it Necrophilia if she's still twitchin' ?
- Slither
- spetz
I think it would be a lot cheaper than that.
The mechanic who did my conversion (6A12 MIVEC into lancer) had an evo V engine sitting there as well, it was my choice which one I wanted (I chose the MIVEC obviously).
Cost wise it was $8000 for both, but with the evo engine I had to supply an intercooler and pay for the piping. Otherwise no difference. So roughly 9K for the conversion, plus I am sure he would give a couple of grand for the old V6 MIVEC engine from an FTO to put an evo engine in.
This was with FTO seats, climate control, evo brakes, new clutch etc etc. If you look hard... you will find a good mechanic at a good price
