Replacement rear bearing advice needed!
Re: Replacement rear bearing advice needed!
Vectose wrote: Sat Sep 08, 2018 11:54 am If you don't have ABS then it either isn't a version R or it's been removed.
Nek minnut just blue seats
Rob Furniss
Post by Rob Furniss »
Rob Furniss
Wonder if ABS has been removed then, says it's a GPVR2. Or hey forgot to put it in at the factory.
Even my facelift GPX has ABS, thought all facelifts did.
GazGPvR
Post by GazGPvR »
I'd say it was removed, seeing as though the relays are not there anymore. I have the docs that came with it when it was imported into Australia
Gaz
GazGPvR
Post by GazGPvR »
Never even knew there was a GPvR2!
Gaz
GazGPvR
Post by GazGPvR »
If it's a Version R 2, must be worth double :lol: :lol: :lol:
Gaz
Worth half
GazGPvR
Post by GazGPvR »
Yea probably! I'll be selling her soon anyway
Gaz
Woyta
Post by Woyta »
https://www.viamoto.co.uk/proddetail.ph ... ABS+Models
Rear Wheel Bearing - Rear Hub - Mitsubishi FTO NON ABS Models
The Reason that this cannot be used is that FTO's with ABS have extra holes to enable an ABS ring to be bolted on which this does not have.
With the price of the ABS ones being astronomical there is nothing to stop you drilling your own holes and bolting on the ABS Ring BUT you will need someone who knows what they are doing ie An Engineering Company
I am going to try this way. I dont care if will have working ABS on my 1995 GR. I got it as track toy.
