wiring tweeters????
wiring tweeters????
n00b - I got passed down my FTO from my uncle. He has placed tweeters on the back tray next to the 6x9's but didn't hook them up. I would take them out but that would leave two screw holes in my back tray so i decided to leave them in.
So was just wondering if it would be ok if i just wired them up to the 6x9's? Or how should i wire them?
If not, if i do take them out is there a way to fill in the screw holes?
- Foe
If your using the factory wiring for the fronts. I found that theres wireing for tweeters preinstalled behind the dash vents (where the cloth is either side of the car) wich you can just grab some tweeters from jarcar and hook them up and they go.
Sounds pretty good and brings the stage higher up the front. The tweeters face towards the windsreen but seems to be reflected really well. Worked for me anyhow.
- Daz_FTO
- payaya
3 ways 4 ways 6 x 9 are total rubbish! The only reason they are on the market is becuase the average consumer doesnt know squat about car audio, so they believe bigger and more ways is better. Also the other reason is to fill the 6 x 9 holes we have in our cars.
A semi decent set of splits will murder 6 x 9's anyday.
- onnzo
I was reading the autospeed article re wiring in tweeters and noticed that they removed the capicator from the jaycar tweeters. They believed that there was already a capicitor inline somewhere in the stock lexus wiring that supplied the signal to the stock tweeters.
Does anyone know if the FTO is the same? ie. does it have capicators inline somewhere? I have a stock gr and only the wiring is there, I cant see any capicators.
Mike
Mike
- FTO338
Hehehe maybe yours, but i'm sure lots of other owners including myself would disagree their speakers are crappy.ruchi wrote:any speaker in the front door will have crappy trebble as it's aimed straight at your knees and not your ears
- FTO338
Now i'm really lost, cause the original tweeter are on both size of the dash........
My Tweeters are mounted higher up on the door. I knew what you intended to say, I was just trying to stir you up!ruchi wrote:Are your tweeters down the bottom where the grill is or higher up on your door? (The original reference is to the speakers mounted behind the grill at the bottom of the door).
