Long lost SA member
- c3rbera
Long lost SA member
Got all the goodies (there weren't many..) off it today.
Was defected apparently..
Manual '95 GPXsilverGPX wrote:Nice supra
Re: Long lost SA member
So you got the rear wing......
- c3rbera
And a floor console (put a crack in it taking it out but not too bad)
And...a factory Momo steering wheel...Nothing else too awesome but yeah haha. I'm happy!
- bjk
- Totes
Can't see on phone, what was it? vR?
Momo wheel probably wont fit without modification if its an airbag wheel. Has a different contact on the top of the indicator/wiper unit (you probably have the non airbag unit). You possibly should have grabbed the boot too as the GPvR wing has different mount holes to the stock wing.
Are you sure? My version R wing fitted my silver car's boot that had a standard wing. Or is it the centre post that is different?dstocks wrote:You possibly should have grabbed the boot too as the GPvR wing has different mount holes to the stock wing.
- c3rbera
Yep, got some damage though.bjk wrote:Can't see on phone, what was it? vR?
Mmm yeah I know about that one..this was a pre-facelift wreck so they modified it here too..dstocks wrote:Momo wheel probably wont fit without modification if its an airbag wheel. Has a different contact on the top of the indicator/wiper unit (you probably have the non airbag unit)
Steering wheel got first dibs from the one who told me about the wreck. Goes to me if it doesn't fit for them.
Gonna need clarification on the boot lid..might try removing my wing and lining this one up..?
- vanadinite
i want that wing!! cause i have that colour!!!!
Have a go, it's only like 6 bolts/nuts. Takes 2 minutes to get it on and off.c3rbera wrote: Gonna need clarification on the boot lid..might try removing my wing and lining this one up..?
I think you might find that the centre post is the problem.
- c3rbera
PM repliedvanadinite wrote:i want that wing!! cause i have that colour!!!!
Hmm yeah that'd be right, I was told I could use some stupidly strong double sided tape (it exists apparently) to make it stick if I have to. Will check it out though.Daniel2019 wrote:I think you might find that the centre post is the problem.
Nah, centre posts are the same its the side ones that are in different places.
Are you sure? My version R wing goes straight onto a boot with standard wing holes. Unless the wing was previously modified?dstocks wrote:Nah, centre posts are the same its the side ones that are in different places.
Absolutely positive. Standard wing has 2 of the press clips and one threaded bolt and GPvr has 2 threaded bolts and one clip. Also, the GPvR wing has one of the threaded bolts on the outer seam. None of the standard wing fittings are on the outer seam. Also, ive had to modify one in the past to fit. You have to drill....
Interesting. Maybe the one you gave me was already modified. I had absolutely no problems when test fitting it to old old silver bucket.dstocks wrote:Absolutely positive. Standard wing has 2 of the press clips and one threaded bolt and GPvr has 2 threaded bolts and one clip. Also, the GPvR wing has one of the threaded bolts on the outer seam. None of the standard wing fittings are on the outer seam. Also, ive had to modify one in the past to fit. You have to drill....
- c3rbera
....so if I keep my standard boot lid and drill extra holes to make it fit, I'm gonna have more holes next to the wing itself leftover?
You would get those welded up.c3rbera wrote:....so if I keep my standard boot lid and drill extra holes to make it fit, I'm gonna have more holes next to the wing itself leftover?
My advice is to go get the boot that it came off (its the same color as your car anyway isn't it?)
Then you have a spare and dont have to hack up your one.
- c3rbera
My car is black, this is blueDaniel2019 wrote:You would get those welded up.c3rbera wrote:....so if I keep my standard boot lid and drill extra holes to make it fit, I'm gonna have more holes next to the wing itself leftover?
Got a red facelift bar coming as well, not to mention my boot lid has paint damage. At this rate, I'm doing a lot of painting as it is...
Full respray is on the tables.
My bad, looks black
- ObsidianRadio
There's an FTO at U-Pull-It!?
f**k.
f**k.
- kiz
- SA Coordinator
WTF, how did you manage that find
1998 Mitsubishi FTO GPVR AERO
