Exhaust specifications..
- FTOcrazy273
What's the loudest legal set up you can have? and also the loudest illegal
SchumieFan wrote:FAPTASTIC!
Re: Exhaust specifications..
Loudest legal is 90DB lol stock exhaust is 89DB so any mod is illegal essentially
- FTOcrazy273
Oh okay cheers haha, whats a good set up though? I'm thinking about getting a custom exhaust system made. Something similar to the 5zigen pro racer ZZ system.Sahin wrote:Loudest legal is 90DB lol stock exhaust is 89DB so any mod is illegal essentially
Also are ash air intake pipes any good with a hks pod filter attached?
- ZFL45H1
I wouldn't even worry about legality I've got hurricane extractors custom y piece amd the rest straight though till the rear muffler and its small and hell. No cat no resonator and never been pulled over just chose your times wisely when to open her up
Yeah f**k it just get whatever you want
Phil has a very loud exhaust, my old smurf did too when it was at higher RPM.
- ZFL45H1
- FTOcrazy273
Sounds mint, how much did it cost man?ZFL45H1 wrote:I wouldn't even worry about legality I've got hurricane extractors custom y piece amd the rest straight though till the rear muffler and its small and hell. No cat no resonator and never been pulled over just chose your times wisely when to open her up
What set up did you have in the smurf? and what set up does phil have? I want something really deep and gruntyDaniel2019 wrote:Yeah f**k it just get whatever you want
- ZFL45H1
I bought it off a member here for 800 I think maybe 850 was told it was around 1200 also came with a resonator but im currently using the stright pipe replacement
- FTOcrazy273
That's a sweet deal Know where I could get one? Or track one down?ZFL45H1 wrote:I bought it off a member here for 800 I think maybe 850 was told it was around 1200 also came with a resonator but im currently using the stright pipe replacement
- ZFL45H1
I believe be bought it from castle hill exhausts in sydney
- FTOcrazy273
Cheers, I'll get onto it and see what can be done!ZFL45H1 wrote:I believe be bought it from castle hill exhausts in sydney
- ZFL45H1
- Herron
I got a quote from castle hill last week for 250$ mandrel bent mild steel axle back (red back muffler) if that helps.FTOcrazy273 wrote:Cheers, I'll get onto it and see what can be done!ZFL45H1 wrote:I believe be bought it from castle hill exhausts in sydney
This...FTOcrazy273 wrote:and what set up does phil have?
But really...
Turn it up loud
Even better if you have surround sound and sub on your PC.
- FTOcrazy273
What's it sound like man? how many decibels etc?Herron wrote:I got a quote from castle hill last week for 250$ mandrel bent mild steel axle back (red back muffler) if that helps.FTOcrazy273 wrote:Cheers, I'll get onto it and see what can be done!ZFL45H1 wrote:I believe be bought it from castle hill exhausts in sydney
Fark Phil that's absolutely JIZZWORTHY!! How much did it cost? And what is it?PHIL069 wrote:This...FTOcrazy273 wrote:and what set up does phil have?
But really...
Turn it up loud
- FTOcrazy273
Nice photo though wouldn't be surprised if it actually did take off like that
- Herron
I didn't end up getting mine at castle hill, went to Liverpool and got a hurricane one. I would recommend them, service was good. Got to try out a range of mufflers, from stock sounding to straight through. In regards to the db level, like these guys said, if the stock exhaust is 89db pretty much every after market system will be illegal. What's in forced is a different matter..
My exhaust sounds like a deeper more ballsy stock muffler, but if your getting a cat back you could play around with the resonators to get a different sound, although I think that would make it louder.
- FTOcrazy273
Herron wrote:I didn't end up getting mine at castle hill, went to Liverpool and got a hurricane one. I would recommend them, service was good. Got to try out a range of mufflers, from stock sounding to straight through. In regards to the db level, like these guys said, if the stock exhaust is 89db pretty much every after market system will be illegal. What's in forced is a different matter..
Thanks for your help Herron, would you be able to upload a video so I could hear what the hurricane sounds like?
- Herron
https://www.youtube.com/watch?v=pzl9QnVb3H4
not mine, another club members. same brand of muffler, its a catback i think, instead of axle back. probably the same muffler as mine though.
And this is what a straight pipe sounds like
