Had a search for it and found one code, but couldn't tell if it was left or right. Anybody give me a hand? Just having a look at how much a new unit will set me back from Amayamamama or anywhere else people know to get them.
Cheers guys.
Front passenger hub assembly part number
- bjk
- Totes
Re: Front passenger hub assembly part number
What's wrong with the one you've got? If it's the bearing it can be pressed out and have a new one pressed in. I think they're like $30 per side.
- Shhtuart
This.Vectose wrote:What's wrong with the one you've got? If it's the bearing it can be pressed out and have a new one pressed in. I think they're like $30 per side.
Bearings are replaceable, jap bearings are around the $90 (NSK, Koyo)
Cashie at a mechanic for what Vectose said, if you take the hub assembly out yourself.
- ZFL45H1
The problem is that the inner and outta part of the actual hub has worn down to much so when the new bearing is in it still has play no matter how tight you do the nut up
- bjk
- Totes
^ what he said. Hub is gone. Could do it cheap though Shane-o, but given it'll be a while yet, can afford to get a new one.
- bjk
- Totes
I've got spare hubs. What side? ABS?
- bjk
- Totes
Left side. Non-abs as far as I'm aware. Question. How much can the hub be swapped around? The caliper mounts are attached to the hub, don't really want to have to get a new one fabbed up if I don't have to.Bennoz wrote:I've got spare hubs. What side? ABS?
Ed, never mind, Tim just got back to me.
