Fuses Keep Blowing
- ObsidianRadio
Fuses Keep Blowing
Fuses 1 and 4 in the engine bay fuse box (tail lights and gauge cluster lights) keep blowing. I replaced the fuses and they blew moments after turning them on. This happened twice in a row.
Has anybody faced similar issues in the past and if so; what's a likely cause of this? Looking to rectify this ASAP.
Cheers!
Cheers!
Re: Fuses Keep Blowing
Probs a pinched wire when reinstalling the tail lights
And maybe also the case when reinstalling the gauge cluster
And may have a faulty dinner blowing both fuses
- SchumieFan
^this more than likely a pinched tail light wire
Not a faulty "Dinner"Sahin wrote:Probs a pinched wire when reinstalling the tail lights
- ObsidianRadio
I assume you meant the dimmer... Sahin, how much? Hahahaha
Bro you can't just buy your way out of everything lol there's no factory dimmer, just rip it out lol
- ObsidianRadio
How? Lol
I need this thing working perfectly before the bonfire trip :/
In my case it was pinching the tail-light wiring.
- ObsidianRadio
I find this strange as I haven't taken the lights out of this one since September when I sprayed it... Would it also be causing the gauge cluster fuse to blow?Technikhaus wrote:In my case it was pinching the tail-light wiring.
When it took out my tail lights it also took out my gauge lights.
Could also be a pinched wire somewhere else, as it's quite a long harness from the front to the rear of the car.
One way of looking at it is, what have you done to the car recently?
Yeah sounds like pinched wire. Obviously short circuiting somewhere. Check all the wires that are related to it for shorts/cuts/etc.
- ObsidianRadio
This is going to take forever Hahahaha
I'll f**k around in the boot for a while and just see if any of the cargo back there or the sub box hasn't pinched anything.
Stop runnin' too much NOS!
You're lucky that 200 shot of nitrous didn't blow the lid off your fuse box!
You probably pinched the tail light wires after your respray.
They have just now worn through the insulation to cause a short to chassis.
Take out you tail lights and check, it will only take 10 mins.
- ObsidianRadio
Was the angel eyes guys, cheers for helping out at the bonfire!
Check your angel eye light wiring..
- ObsidianRadio
Yes, Martin.Daniel2019 wrote:Check your angel eye light wiring..
- kiz
- SA Coordinator
I told you prior to even leaving for the bonfire that it was the angel eyes mateObsidianRadio wrote:Was the angel eyes guys, cheers for helping out at the bonfire!
1998 Mitsubishi FTO GPVR AERO
