Torque Converter Bolts
Am I right in assuming I have to use a torque wrench on the torque converter bolts? I know they need loctite, but not sure about how tight. And if I do need to torque them, Any idea how tight?
Thanks in advance
Thanks in advance
Re: Torque Converter Bolts
Think they're close to 100nm if I remember correctly.
You need to hold the engine from turning, what I did was have someone hold the crank bolt with a breaker bar while I tightened the flywheel bolts.
Thanks Vectose, I thought it would be around that.
Workshop Manual says 45 - 52 Nm
I stopped the engine from spinning with a long breaker bar on the crank bolt going to the ground, because I didn't have anyone to help
Yep, thats exactly what I was going to do. Thanks for the confirmation on the settings too.PHIL069 wrote:I stopped the engine from spinning with a long breaker bar on the crank bolt going to the ground, because I didn't have anyone to help
It's 45-52nm for the bolts that attach the torque converter to the plate. The bolts that attach the plate to the engine are 98nm.
- Flywheel Bolts.jpg (88.79 KiB) Viewed 374 times
On all of those bolts, I just set the rattle gun to 'f*cken tight'
Bet ya wish missus had that settingBennoz wrote:On all of those bolts, I just set the rattle gun to 'f*cken tight'
You really should just steer clear of commenting on the topic of bolts, especially these sorts of bolts, Destinationshearitofftoby.destinationtoby wrote:Bet ya wish missus had that settingBennoz wrote:On all of those bolts, I just set the rattle gun to 'f*cken tight'
2/10 for the joke.
I know I knowBennoz wrote:You really should just steer clear of commenting on the topic of bolts, especially these sorts of bolts, Destinationshearitofftoby.destinationtoby wrote:Bet ya wish missus had that settingBennoz wrote:On all of those bolts, I just set the rattle gun to 'f*cken tight'
2/10 for the joke.
2.5/10 cos it was quick as f**k?
- bjk
- Totes
About as quick as your last f**k.destinationtoby wrote:I know I knowBennoz wrote:You really should just steer clear of commenting on the topic of bolts, especially these sorts of bolts, Destinationshearitofftoby.destinationtoby wrote:Bet ya wish missus had that settingBennoz wrote:On all of those bolts, I just set the rattle gun to 'f*cken tight'
2/10 for the joke.
:LNB:
Oh god.. it made it onto the forum!
- bjk
- Totes
It was already latent. Hidden, lurking in the murky depths.
When are we going to get a :LNB: emote, Ben? The forum demands gratification!
This ^Bennoz wrote:On all of those bolts, I just set the rattle gun to 'f*cken tight'
Same goes for hub nuts, gearbox bolts, transfer case bolts...
Anything that is more than a 10mm, really...
- Supplanter
What happens on facebook stays on facebook.bjk wrote:When are we going to get a :LNB: emote, Ben? The forum demands gratification!
