Overheating..
- EmmettJDM
Overheating..
Car only over heats when i go up hills! seems stupid i know...
the top radiator hose is boiling hot and the bottom luke warm?
Think my thermostat is not opening or my radiator is blocked? any ideas
95 GPX [Silver] *parts car now*
96 GPX [Midnight Blue] *current*
- EmmettJDM
Re: Overheating..
also. when i drive with my windows up and hit mivec it sounds like its supercharged! probably not normal xD
Re: Overheating..
Pull thermostat out. Whining could be water pump.
- bjk
- Totes
Re: Overheating..
Yeah do the basics. Thermostat. Radiator cap. Coolant. Temperature sensor.
Silver one did that when I first got it and it ended up being blocked rad though.
- EmmettJDM
Re: Overheating..
i did not even have a thermostat to start with..... just threw one in! its running great. but now it dies when i start it and have to give it a little rev??
Re: Overheating..
Stepper motor.
- bjk
- Totes
Re: Overheating..
Stepper. It's the new starter!Daniel2019 wrote:Stepper motor.
Re: Overheating..
Nah that was 5 years ago, the year of the stepper. Was right after the year of the borked torque converter.bjk wrote:Stepper. It's the new starter!Daniel2019 wrote:Stepper motor.
Sent from my D5833 using Tapatalk
- bjk
- Totes
Re: Overheating..
We need our own Chinese Calendar. Maybe I'll draw one when I can be bothered.Bennoz wrote:Nah that was 5 years ago, the year of the stepper. Was right after the year of the borked torque converter.bjk wrote:Stepper. It's the new starter!Daniel2019 wrote:Stepper motor.
- vipfto
Re: Overheating..
You mean a half head of hair ago?? But now I think about if i'm balder than you I assume you had implants done
@ OP look at Radiator, Coolant temp sensor, even faulty temp gauge on dash, radiator cap and thermostat.
Doubt water pump if its flowing wont be that.
Another to watch for is heavily clogged condenser and front bar as airflow may be restricted
Re: Overheating..
My vote is for a clogged radiator
