Hi guys,
Just wondering if anyone has replaced their orings in the high pressure hose connection and the low pressure on the power steering pump.
Getting a mad leak on the pump.
Someone has suggested I just take the pump and line into a bearing/seal shop - is this the best option?
Cheers
Power steering leaks / orings
Re: Power steering leaks / orings
Yep I would. Or alternatively just pull out the seals and sh*t you need to replace and go get them matched up.
Sorted.
