tip tronic random gear change????
curse
Post by curse »
hey all
I have recently got my self a 94 model auto with tip, and every time i go down a hill it jumps gears every now and then like from 4TH to 2nd. Is this normal?
and ive noticed it stretches gears out as well when im not accelerating much either from 2nd to thrid. but also on flat road as well as hills. Is this normal.
Lastly does anyone know where i could find some of the spring clips that go inside the sunroof cover slide.
vipfto
Post by vipfto »
first WTTC :D
as for issue reset ECU mate (disconnect battery)
the Invecs gearbox actually learns how the driver drives car and changes accordingly, after a few days it will learn how you drive and then react to your driving style
oh and post up some pics mate :D
Albert
Post by Albert »
Mate i have a similar problem to you
its does to me aswell and other changes
when i drive the automatic gearbox is on 4 then suddenly the car kicks back to 3rd gear and then lights up both N and D on the 3rd gear and does not change anymore when i stop. it just stays on 3rd unless i switch off the car for a bit and goes back to normal. but its been doing it everyday and its annoying.
Has anyone else had this problem?
how do i fix this?
Thanks
^^^^^^ Do what VIP just mentioned, then drive it
Absolutely that is the invecs system using engine breaking to slow you down, so your not rolling down the hill (eg more control)..
Hmm that reminds me of another thread we discussing earlier..... but we wont start that back up again lol
FTEvolution
Post by FTEvolution »
I agree with the ferrari eater, but as for the gearbox taking a while to shift, it could be your torque converter.
It sounds like your tip box is "flaring"... it only gets worse, have it checked.
Smooth and sleepy
koolio1234
Post by koolio1234 »
check the transmission fluids and make sure they are topped up...otherwise just reset the ecu as suggested.
You will be also amazed at what a good fluid change does ;)
vipfto
Post by vipfto »
I8A4RE wrote:You will be also amazed at what a good fluid change does ;)
+1
Albert
Post by Albert »
Heloooo is anyone therrrrrre lolz.
I recall seeing something on the forum about 3rd gear being stuck and back to normal when you switch the car off and on again. the gears D and N are blinking at disame time. do i need to get my TIP fixed or its just ECU or something else.
i think its that bloke from Adelaide that had same problem but cant remember. HELP
Can anyone advise or point me to the right direction.... i wanna join the cruise but not confident it will make it on long travel....!!
So i need to FIX IT....plzzzzz
thanks
Its annoying
:x
Albert wrote:Heloooo is anyone therrrrrre lolz.
thanks
Its annoying
:x
Check the tip box ECU codes:
http://www.ftoaustralia.com/modules.php ... ic&t=14667
Then come back to us.
Albert
Post by Albert »
okay now this bit im a NOOB lolz
what do i use to check the ECU?
ive never done it before
where do i buy one and how much roughly
thanks
Read the link in my above post very carefully. Everything you need is in there.
Albert
Post by Albert »
okay Bennoz
okay ive got the error code
the orange engine light is flashing once per second constantly
the N is flashing wieird, flash sequence
first is a one lights N for 2 seconds ( may be counting quick )
second is same
a 3 or 4 second stop or nothing in between
then 3 flashes after that is a sequence of 1 second interval then stops for a bit and does it all over again
what does this mean? Limp back, i mean leap mode
thanks guys
Albert
Post by Albert »
okay guyz
how do you get the exact error reading?
Ive been looking at other peepz error code
what do you need to buy to pull out error codes out of the FTO
ive tried the 1 pin and grounding but it only comes up as lights and going by Bennoz error code data sheet. But is there another way to do this a reader or something?
vipfto
Post by vipfto »
Albert wrote:okay Bennoz
second is same
thanks guys
by the way i think you have described flashing? it sounds as its error code 23.......
output shaft speed sensor
limp mode is when there is prob and trans effectively goes into a safe mode.
The N light will flash and car will be stuck in third gear, it will make a decent thud when shifting from D-R-P
Storm
Post by Storm »
What vip says makes sense, if it is the output speed sensor get it replaced or at th every least cleaned.
2nd going down hill shows your tip ECU is working well, mine didn't do it until I soaked it then left it in the hot cupboard for a few days. Not actualy to be recommended :roll:
It also recognises my driving style in a few minutes, rather than days. If I start hooning it around it holds onto the gears for longer, as it should, but it keeps holding the gears, even when I drive into a town. It then takes five minutes or so to return to a semblance of normality.
Bill
Albert
Post by Albert »
Thanks guys
by the way where can i buy this input and output sensors?
i want to change both,i have bought new O2 sensors aswell from ebay $60 thanks Simon
I think there is a DIY somewhere on how to change this right
is this also related to my speedometer going nuts as in hitting over 100km when i just sort of go hard on first gear . i wish my first gear did it but im realyy goin 40km damn!!
Thanks
Albert
Post by Albert »
okay i got parts coming in from Camskill to replace both input and output sensor.
but first i tried cleaning it and it worked, but i do get a bit of a jig when i gears down sometimes.not often.
but its not going on Limp mode for now.
Reset ECU
But i have another problem my Speedometer is not working anymore what happened?
i just cleaned the sensors with WD 40. and my stepper motor.
what could be the culptrit, maybe i didnt put it all properly? im sure i did.
my speedo was going but already jumping to certain speeds, now it completly gooner
Anyone?
Thanks guys
vipfto
Post by vipfto »
either speed sensor unit or bad connection at dash
Yeah speedo sensor is at the back of the box, you may have disturbed it pulling input / output sensors out & so on.
