Changing parking light bulb on a GR
- mlevi
Would anybody have any idea how I could change my parking light bulbs as above. Just checking if there is a need for removing the bumper before I actually sit down to do that!
- SchumieFan
what year car? facelift model?(97+)
if its not(94-96) its easy as getting under the car and unscrewing the bulb from the holder
- mlevi
- pete_gpx
Nope, I have a pre-facelift. It's very easy, I didn't even jack the car up, just did it by feel. You just need to locate the holder then twist and pull. Pull out the old wedge bulb, pop in the new, then twist the holder back in.
- bas
doing it by "feel" might be a bit hard
try this: go to the front of the lights and undo the one screw u can see, then just poke your head under the bumper have a look and push out the whole cluster.
from there ull have easy acces from the front and u can change it easily.
then to put everything bak just push it bak in, u'll find the spot nd it'll pop bak in nicely
- mlevi
- SchumieFan
- mlevi
Ignore Schumie. He's a kiwi. Comes from the factory with brain damage.mlevi wrote:That was uncalled for!!! Sorry if everyone is not as knowlegeable about the car as you...thought thats what this forum was for!!SchumieFan wrote:huh? wierdomlevi wrote:Sorry mate, it is a 94 GR so i believe pre-facelift model. So i am guessing I have a bit of work trying to swap em eh!
- SchumieFan
what?
no! i meant wierdo cause i told u how to change it on a pre-facelift, then you said sorry u have a pre facelift.
settle grettel!
settle grettel!
SchumieFan wrote:what year car? facelift model?(97+)
