Changing parking light bulb on a GR
mlevi
Post by mlevi »
Would anybody have any idea how I could change my parking light bulbs as above. Just checking if there is a need for removing the bumper before I actually sit down to do that!
what year car? facelift model?(97+)
if its not(94-96) its easy as getting under the car and unscrewing the bulb from the holder
mlevi
Post by mlevi »
Sorry mate, it is a 94 GR so i believe pre-facelift model. So i am guessing I have a bit of work trying to swap em eh!
pete_gpx
Post by pete_gpx »
Nope, I have a pre-facelift. It's very easy, I didn't even jack the car up, just did it by feel. You just need to locate the holder then twist and pull. Pull out the old wedge bulb, pop in the new, then twist the holder back in.
bas
Post by bas »
doing it by "feel" might be a bit hard
try this: go to the front of the lights and undo the one screw u can see, then just poke your head under the bumper have a look and push out the whole cluster.
from there ull have easy acces from the front and u can change it easily.
then to put everything bak just push it bak in, u'll find the spot nd it'll pop bak in nicely
mlevi
Post by mlevi »
Thanks pete and bas, will give it a shot...
I actually went with the feel and replace because I could not get the lights out with reasonable pressure being applied from behind...mind you the passenger side one was a pain thanx to the stock CAI piping...
Thanks heaps guys...
mlevi wrote:Sorry mate, it is a 94 GR so i believe pre-facelift model. So i am guessing I have a bit of work trying to swap em eh!
huh? wierdo
mlevi
Post by mlevi »
huh? wierdo
That was uncalled for!!! Sorry if everyone is not as knowlegeable about the car as you...thought thats what this forum was for!!
mlevi wrote:
huh? wierdo
Ignore Schumie. He's a kiwi. Comes from the factory with brain damage.
I find that very offencive Ben :evil: Im going to go consol myself with my pet sheep she always makes me feel better :lol:
Bennoz wrote:Ignore Schumie. He's a kiwi. Comes from the factory with brain damage.
vipfto wrote:offencive
Exhibit A :lol:
what?
no! i meant wierdo cause i told u how to change it on a pre-facelift, then you said sorry u have a pre facelift.
settle grettel!
SchumieFan wrote:what year car? facelift model?(97+)
8O
