Just a Question
Pkat
Just a Question
Post by Pkat »
Is it true no matter what you do that the v6 engine of the fto will always have a oil leak? because i just got a engine rebuild just recently and the mechanic guy is like no matter what all v6's tend to have a oil leak. So he said it will last about 3 to 4 years before i get the same problem again.
koolio1234
Post by koolio1234 »
When your engine seals are doing their job then i dont see why your engine should leak. Of course, over time seals will wear and you'll blow a gasket, then it is expected to loose a little oil. A little preventative maintenance will usually prevent oil leaks. ie, changing all engine seals and gaskets at a major service where the engine is worked on.
vipfto
Post by vipfto »
No it shouldnt mine does not leak at all, just because there 2 heads (double the amount of seals gaskets etc) does not mean that it will leak esp if job done right
I think he is referring to the angle that "V" engines lay on...... BUT HE IS STILL WRONG.
If you have a leak replace the seal, if done correctly leak gone.... and most seals will last way longer than 3-4 years
Pkat
Post by Pkat »
sweet thanks guys it actually made me consider of selling off the car since i thought this problem occurred regularly. lol the guy told me it'll last about 3 to 4 years =.=.
Thanks for the info guys.
Mines a 1995 model no leaks ever.
Mines a 96, had 2 different engines in it & neither of them leaked.
Mines 94 and now turbo'ed and I have nevr had a drop of oil on the floor.
The rocker cover gasket looks like it might be starting to leak a little now but thats pretty common
FTEvolution
Post by FTEvolution »
Bennoz wrote:Mines a 96, had 2 different engines in it & neither of them leaked.
Mine leaked like a sieve... until I bothered to get underneath and tighten up the oil return line :twisted:
Smooth and sleepy
RallyMad
Post by RallyMad »
I8A4RE wrote:Mines 94 and now turbo'ed and I have nevr had a drop of oil on the floor.
Mine had some small leaks when I bought it 5 years ago. Replaced the half moon seals and rocker cover gaskets and have been completing leak free ever since.
