Some canister thingy
When i was changing my fuel filter i found a canister thingy ziptied to one of the rear intake manifold brackets with two vacuum lines attached to it from the throttlebody. What is this?
It rattles when u shake it so it must be broken, so i just unplugged it and put a joiner between the lines. Can i do this?
- aza013
- NSW Coordinator
Re: Some canister thingy
pics would help
it looks like this
- Kustom
- topgun
For ants???Kustom_FTO wrote:Its a penis pump
- brad_gpx
for queenslanderstopgun wrote:For ants???Kustom_FTO wrote:Its a penis pump
- topgun
brad_gpx wrote:for queenslanderstopgun wrote:For ants???Kustom_FTO wrote:Its a penis pump
- bduffman
Where were they connected to ( where on throtal body cause there's only 1 vac line and its a small one no idea where it goes to though
Do you have a fuel vapour canister ?
Either way that thing didn't come with the car only canister I can think of is the fuel vapour one that's normaly in drivers fender area
yeah ive got 4 small vacuum lines coming off the back of mine.
I know about the fuel vapour canister, mines disconnected, is that normal?
topgun wrote:brad_gpx wrote:for queenslanderstopgun wrote:For ants???Kustom_FTO wrote:Its a penis pump
Certainly looks like a fuel vapour cannister. Is the factory one not up under the front bar? (behind drivers side fog light?)
yep its under there. it has no pipes going to it though?
- aza013
- NSW Coordinator
Looks like the last owner relocated it. Do you still have the plastic liner in the wheel arch's?
i thought the canister was meant to be attached to the fuel tank? this ones attached to the throttle body. Yeah i did have the arch's in i took em out cos they were fucked. He could of had them out cos it had a veilside front on it when i bought the car.
- Chiinkstarrh
ROFL !! hahahahahah!!Kustom_FTO wrote:Its a penis pump
Factory it should be up under the bumper. If not, she's been pranged & its been moved. Ghay.silverGPX wrote:i thought the canister was meant to be attached to the fuel tank? this ones attached to the throttle body. Yeah i did have the arch's in i took em out cos they were fucked. He could of had them out cos it had a veilside front on it when i bought the car.
