Some canister thingy
When i was changing my fuel filter i found a canister thingy ziptied to one of the rear intake manifold brackets with two vacuum lines attached to it from the throttlebody. What is this?
It rattles when u shake it so it must be broken, so i just unplugged it and put a joiner between the lines. Can i do this?
Re: Some canister thingy
pics would help :?
it looks like this
help :)
Its a penis pump
yay!
topgun
Approved FTO Australia Trader
Post by topgun »
Kustom_FTO wrote:Its a penis pump
For ants??? :lol:
brad_gpx
Post by brad_gpx »
For ants??? :lol:
for queenslanders
topgun
Post by topgun »
brad_gpx wrote:
For ants??? :lol:
for queenslanders
:cheeky:
bduffman
Post by bduffman »
Where were they connected to ( where on throtal body cause there's only 1 vac line and its a small one no idea where it goes to though
Do you have a fuel vapour canister ?
Either way that thing didn't come with the car only canister I can think of is the fuel vapour one that's normaly in drivers fender area
yeah ive got 4 small vacuum lines coming off the back of mine.
I know about the fuel vapour canister, mines disconnected, is that normal?
topgun wrote:
brad_gpx wrote:
For ants??? :lol:
for queenslanders
:cheeky:
Certainly looks like a fuel vapour cannister. Is the factory one not up under the front bar? (behind drivers side fog light?)
yep its under there. it has no pipes going to it though?
Looks like the last owner relocated it. Do you still have the plastic liner in the wheel arch's?
i thought the canister was meant to be attached to the fuel tank? this ones attached to the throttle body. Yeah i did have the arch's in i took em out cos they were fucked. He could of had them out cos it had a veilside front on it when i bought the car.
Chiinkstarrh
Post by Chiinkstarrh »
ROFL !! hahahahahah!!
silverGPX wrote:i thought the canister was meant to be attached to the fuel tank? this ones attached to the throttle body. Yeah i did have the arch's in i took em out cos they were fucked. He could of had them out cos it had a veilside front on it when i bought the car.
Factory it should be up under the bumper. If not, she's been pranged & its been moved. Ghay.
