Ive recently went for a drive, as i was coming back home ive come into a really big problem,
When i press the accelerator the car starts to stutter and feels like its slipping and doesnt want to move anywhere,
it happens more as i push the accelerator pedal down more,
Please anyone have a solution to this problem as it is a Tiptronic i dont know what it could be.
Car is running fine overall only this problem..
Big Problem, Tiptronic please help
- vipfto
Re: Big Problem, Tiptronic please help
does the car rev harder but go nowhere? sorry bit vague description there, is it like a slipping clutch?
Yes basicly as you described, the car revs but doesnt want to go, if i press it slowly it picks up very slowly, its a auto 4 speed and now today it goes only on gear 3 and the N sign flashes, i think its a really big problem, PLEASE HELP !
- vipfto
ok first thing is check error codes there is a link on this site.
next CHANGE FLUID most likely the cause
i have already changed the fluid and the filter
- vipfto
aslong as used correct fluid and proper amount next will be either fuse or input speed sensor or torque converter.
But first check error codes mate
ok i will check the error codes,
the car drives like sh*t in tiptronic mode, i was going to change the gearbox anyway, would that get rid of the problems ?
vipfto wrote:But first check error codes mate
- Valandis91
ft02nv wrote:Ive recently went for a drive, as i was coming back home ive come into a really big problem,
this happened to me once awhile ago...
i think it was from my tranny fluid overheating...
