Big Problem, Tiptronic please help
ft02nv
Post by ft02nv »
Ive recently went for a drive, as i was coming back home ive come into a really big problem,
When i press the accelerator the car starts to stutter and feels like its slipping and doesnt want to move anywhere,
it happens more as i push the accelerator pedal down more,
Please anyone have a solution to this problem as it is a Tiptronic i dont know what it could be.
Car is running fine overall only this problem..
Re: Big Problem, Tiptronic please help
does the car rev harder but go nowhere? sorry bit vague description there, is it like a slipping clutch?
ft02nv
Post by ft02nv »
Yes basicly as you described, the car revs but doesnt want to go, if i press it slowly it picks up very slowly, its a auto 4 speed and now today it goes only on gear 3 and the N sign flashes, i think its a really big problem, PLEASE HELP !
ok first thing is check error codes there is a link on this site.
next CHANGE FLUID most likely the cause
ft02nv
Post by ft02nv »
i have already changed the fluid and the filter
aslong as used correct fluid and proper amount next will be either fuse or input speed sensor or torque converter.
But first check error codes mate
ft02nv
Post by ft02nv »
ok i will check the error codes,
the car drives like sh*t in tiptronic mode, i was going to change the gearbox anyway, would that get rid of the problems ?
vipfto wrote:But first check error codes mate
Valandis91
Post by Valandis91 »
ft02nv wrote:Ive recently went for a drive, as i was coming back home ive come into a really big problem,
this happened to me once awhile ago...
i think it was from my tranny fluid overheating...
