How many different driveshaft?
- FTO-BOY
Re: How many different driveshaft?
bduffman.. they do have a complete drive shaft. they just dont advertise it on the website. call them up and ask them.
- bduffman
yea they only have 1 instock so im guessing it was your one
and they dont sell the inner ones so im guessing they dont get changed when they do the swap overs
so may as well just fix my ones less issues as im getting them swaped when i get the clutch done
- bduffman
Hey guys forgot to add this
My mechanic is getting my cvs rebuilt whole shaft so in and out joints its $180 a shaft there is that company above but as we all know there's a few different shafts so this way you know the shaft will fit
Problem is may take a few days to rebuild them ( not quite sure how long mechanic just said a few days could be 1 though who knows
Ill be getting this done in the next week or so
Will let you know how it goes
- Shane001
Just be sure he gets the correct inner joints, this is where the major differences are
- bduffman
Not sure if they do replace them or if they just rebuild them ( new bearings and stuff ) ill ask what they did after the works done
- Shane001
Well if they're doing a proper rebuild they should be replaced, as the inside of the joint is what wears. And yes new bearings, but not much point putting in new bearings with a worn joint.
