Can i change auto gearbox oil filter without changing the gearbox oil?
Will it spills everywhere if i just remove the atf filter w/o draining the atf?
(The atf filter is facing upwards instead of downwards like the engine oil filter.)
Thanks. Cheers!
(i got it serviced last year and for don't what reason the shop only change the atf but leave the filter as it is. I checked the atf and it's pinkish so i guess they did actually change the fluid.)
Change ATF Filter w/o changing ATF?
- phunkydude
Re: Change ATF Filter w/o changing ATF?
Yeah you can. Just make the sure the car is off lol. Otherwise *squirt!* right in the eye lol
- spency
That's what she said.Bennoz wrote:Otherwise *squirt!* right in the eye lol
End of story.
I call lies mate. You're a dad now yeah? You got it somewhere else....spency wrote:That's what she said.Bennoz wrote:Otherwise *squirt!* right in the eye lol
End of story.
Whats the best oil filter to use for it as ill change it for him.
Its the same Z411 you use for engine oil. If you're pedantic about types of filters, then go for a Coopers Z411 rather than a Ryco Z411.
Most places usually stock both these days.
